Originally Posted by BigAl
If I remember correctly, I saw in a manual years ago that the back of the propane fridge is supposed to be close to the wall of the trailer so that the convection air current has to pass over the tubing on the back of the fridge. With the curve in the body of our trailers it is not possible. A really good fix would be to install a baffle a few inches from the tubes starting above the gas valve and extending up to near the top of the fridge. Install your fans at the bottom directing the air flow up the back of the fridge. If I pull my fridge, that is what I will try.
I agree wholeheartedly that the chimney arrangement is the best way to achieve good cooling while minimizing the amount of power used by the system. In my study to understand the operation of the absorption refrigerator, I found that the more heat that can be exchanged at the finned heat exchanger at the top of the refrigerator, the better the system will cool. The most energy efficient way to get the air to pass through the heat exchanger is with a chimney. You let convection to do work of drawing outside air over the exchanger.
In a square box trailer, it's fairly easy to achieve the chimney design that gives the convection. But in the Airstream we are driving a square peg into a round hole. In my trailer in particular, the vent on the top of the trailer is actually inboard from the plane of the back of the refrigerator. While the chimney is far to wide at the bottom, it is a bit too narrow at the top. That leaves a fairly small slot for the convection air. That's the reason I went with the fans. They burn
12 volt power and thus are less energy efficient, but they do actually get the job done. And they get it done well. At this moment, the outside air is 98 degrees, the inside temperature of the Airstream is 84. and the Airstream refrigerator is 39.
I actually gathered quite a bit of data from my setup before making the decision that I did. I have a dozen trials where I varied what I could and then measured the temperatures on the trailer skin, at 5 different points in the absorption system, and inside the refrigerator. I did not introduce a chimney. That may work equally well or better. But I went where the data led me.
For a decent discussion of the operation of the absorption refrigerator, see
https://en.wikipedia.org/wiki/Absorp...itial%20states.
