Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Refrigerators
Old 08-08-2003, 03:26 PM   #1
Kathy Parker's Avatar
Smile Frig replacement
I have to replace a frig in a 31 ft airstream, and have deceided to go with regular frig. Any advice on where to purchace one that will fit through door.
Kathy Parker is offline   Reply With Quote
Old 08-08-2003, 03:29 PM   #2
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
Sams Club, Costco or even Home depot. Get an apartment or dorm sized refer. You may have to take the door off but, they will fit in.
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
Old 08-09-2003, 07:29 AM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Smile
Anyplace that sells em, but I am not sure you'll get an exact fit. Some mods might have to be done to the casing.
I assume that you stay at places that have electric hookups or have a generator.
That is one of the nice things when I go boondocking. Being able to run the fridge on LP gas.
Old 08-09-2003, 10:34 AM   #4
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
I've even run mine on LP when at a full hookup resort. Because their voltage was too poor to run everything I wanted....
-Tim
1960 International Ambassador 28'
2001 Silverado 2500HD CC 6.0L 4.10
Check out my book: Restoring a Dream
Check out my Airstream book for kids!: Airstream Adventures
theVAP - Airstream Podcast
Safari Tim is offline   Reply With Quote
Old 08-27-2003, 12:07 PM   #5
Send a message via Yahoo to Fun-Lovin
Im in the same boat here. I have found the following at home depot that im looking seriously at. The first is 4 cubic ft and is approx 22 1/2" deep, 20 1/2" wide, and 45" tall has a stainless steel finish to it, the fridge is seperate from the freezer and uses .95 amps, cost $199. The second by the same company same width and depth but stands 58" tall is 8 cubic ft again seperate fridge and freezer, uses 1.4 amps.
The shorter one will fit where my existing fridge is and has 13" above it (big enough for a microwave).
Here is my question and Ive already checked on the required wattage > 500 on startup. Has anyone run a standard 110 ac fridge on a dc-ac converter? I would use it primarly when its being towed.
Greg
Fun-Lovin is offline   Reply With Quote
Old 08-27-2003, 03:57 PM   #6
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Well, 1.4 amps at 120 volts is gonna be more than 14 amps at 12 volts, due to the inverter inefficiencies. I guess you could do it, but that's a pretty heavy load to run thru the wire from the alternator, thru the connectors, all the way thru the fuse block and back to the fridge.
If you decide to go that way, you might wanna check all the connections, at least, if not upgrade some wire sizes... I'd sure try it in the driveway for a few hours to make sure none of the smoke gets out of the wires...
Don
drboyd is offline   Reply With Quote
Water heater replacement Craig Water Heaters, Filters & Pumps 36 12-18-2014 09:13 AM
Dometic Frig seals replacements davidlaxson Refrigerators 3 12-08-2003 09:33 AM
Suburban Furnace Replacement Craig Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-31-2003 01:53 PM
Frig replacement.... Silver Bullet Refrigerators 1 12-19-2002 10:10 PM
