Old 06-27-2021, 05:51 PM   #1
ITSNO60's Avatar
Tucson , AZ
Fridge Vent cooling mods?
I want to add a couple or even 3 cooling fans to my upper outside vent to help move more air but there are loads of them on Amazon, even some that are made for the purpose but pricey and poor reviews. If anyone has done this I would be interested to know which fans you used, my vents only have holes at the top and bottom of each vent (see pics), I wish there was another row in the middle instead of 3" of solid plastic. I will need to use 120mm fans and angle them into one of the vent areas. There is presently one 4" fan down under the upper fins on the rear of the unit but it is quite anemic.
My other option is to install a roof vent but there is not much room depth wise, maybe 2.5" but I could go with something oblong maybe 2" x 12" to fit a curved roof but would still want a fan or two.
ID:	398340   Click image for larger version
Brian
ITSNO60 is offline   Reply With Quote
Old 06-27-2021, 07:47 PM   #2
2007 16' International CCD
Somewhere , Colorado
There are lots of threads with many alternative solutions on the forum. I suggest you put “refrigerator fans” in the search box above and you will find what you need.
field & stream is offline   Reply With Quote
Old 06-28-2021, 01:47 AM   #3
Sag Harbor , New York
Thumbs up
That excellent search function may not be, or as easy to use, on the AF App IMO, so here are those search results Brian FYI:
https://www.google.com/search?q=refr...=airforums.com
Hope your trip is continuing to go well.
Peter
Let the music lift you up . . .
[Robert Frost reading live -- 2 minutes]
Old 06-28-2021, 07:23 AM   #4
ITSNO60's Avatar
Tucson , AZ
Thanks for the suggestion, I think I am going to go with Troutboy's design: https://www.airforums.com/forums/f42...ds-166096.html
Not sure if this is how you tag a member but here goes:
https://www.airforums.com/forums/mem...oy-116953.html
Brian
fridge cooling fan is on but fridge is not running hahnstead Refrigerators 5 06-24-2016 06:34 PM
New Fridge, Old Fridge Vent TMT Refrigerators 0 10-17-2015 07:23 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
Fridge Cooling Problems 68International Refrigerators 6 07-10-2002 03:53 PM
