Old 06-20-2020, 06:49 PM   #1
2019 16' Sport
Nelson , British Columbia
Fridge too cold
My 2019 16' Sport has a fridge (Dometic) that the manual says is non-adjustable. It's too cold: things freeze in there.
Any ideas about making it a tad less cold?
Many thanks!!
sdwilsonsct is offline   Reply With Quote
Old 06-20-2020, 07:22 PM   #2
Jmacd's Avatar
2018 25' International
2008 16' International
Forest Knolls , California
We replaced our old fridge with a new Dometic in our 2008 16’ International 2 years ago and have exactly the same problem. Great for beverages, making ice cubes and keeping frozen food frozen, but a problem for lettuce and fruit! Looking forward to any suggestions.
Jmacd is offline   Reply With Quote
Old 06-20-2020, 07:34 PM   #3
Sag Harbor , New York
Put in large containers of cold water, like quart-sized deli containers with lids, and monitor the temp carefully with a good quality thermometer. The added thermal mass will at least even out the temperature swings. Once you get the hang of it, you should be able to add the right quantity of water periodically to come close IMO.
So you don't have the small thermistor device, on the cooling fins in the back of the fridge, which you could slide down for warmer internal temp?
https://www.google.com/search?q=ther...=airforums.com
Call the dealer and ask for a new adjustable fridge, and ask AS to pay for IMO.
Good luck,
Old 06-20-2020, 07:41 PM   #4
PS -- You could gear up and get a LaCrosse indoor/outdoor thermometer with separate sensors in the fridge and freezer, so you don't have to open the door(s) often. We use this at home in the winter, to monitor the crawl space etc. to prevent pipe freeze-ups. Right now there is a sensor in the AS fridge, because we are getting ready for a trip. As I sit here typing, that internal fridge temp is 33.9F [because I also stuck some frozen blue ice in there this afternoon to pre-chill the unit -- no food yet]
https://www.amazon.com/Crosse-Techno...2700212&sr=8-3
Works great!
Also, you could pre-chill [not freeze] large blocks of blue ice to use as an easier thermal mass [instead of the deli containers]. If the fridge is still getting too cold, then add room-temp blue ice to prevent freezing temps. A work in progress, but that LaCrosse thermometer will at least let you monitor things without going nuts!
Good luck,
Old 06-21-2020, 06:03 PM   #5
Jmacd's Avatar
Peter, thanks for the thermistor reminder. Ours was slid up against the bottom of the freezer so I slid it down as low on the fins as possible and we'll see how that goes. We have an Accu-Rite temperature monitor with a sensor located in the freezer and the second in the main compartment. Works great, just been telling us that the freezer is a nice 30-31 degrees F and the main compartment only a degree or two warmer. And since it is a small refrigerator, we have a lot of thermal mass, the fridge is always fully loaded! Thanks, Jim
Old 06-23-2020, 06:45 AM   #6
Silvr_Bullet's Avatar
2017 16' Sport
Woodstock , New York
Fridge too cold
This has been a gem for me keeps air glowing so not to get cold spots. Itís small fits easily on shelf or in door.Click image for larger version
Hensley Hitch
2/100 Amp Hour Battleborn Lithium and upgrade
Silvr_Bullet is offline   Reply With Quote
Old 06-23-2020, 09:25 AM   #7
2016 16' Sport
Miami , Florida
Add warm beer. The energy’s required to chill the beer will raise the temperature of the fridge. Remove the beer once chilled. Replace with warm beer. Consume chilled beer. Repeat all summer and everything will be great.
For units that don’t get cold enough try bourbon.
Shiny16 is offline   Reply With Quote
Old 06-23-2020, 09:38 AM   #8
Any of these ideas making sense to you the OP?
[too cool!]
Old 06-24-2020, 10:50 AM   #9
2019 16' Sport
Yes! Thanks to everyone for these practical ideas.
I looked into the thermistor adjustment already, it didn't help.
The fan looks good. The beer looks better.
Research will be conducted on this weekend's trip.
Old 06-24-2020, 12:21 PM   #10
2017 16' Sport
Beer is a winner
Hensley Hitch
Old 06-24-2020, 01:18 PM   #11
Thumbs up
. . . and if the fridge doesn't stop getting too cold, it means you are not adding warm beer fast enough . . . drink more beer faster!
Old 06-24-2020, 05:42 PM   #12
Are you saying that you have a thermistor, moved it, and saw no change at all in the interior temp of the fridge, using an accurate thermometer inside? Did you wait 24 hours, without adding anything to the fridge, to let the system stabilize? It seems unlikely that moving the thermistor would have resulted in no change IMO.
Or do you not have a thermistor per your OP?
Is it possible that the fridge's control circuit board is bad? How about your dealer or Airstream . . . did they have any suggestions?
Old 06-24-2020, 06:41 PM   #13
2017 16' Sport
Food needs to be not packed together tightly items need to have circulation so not to end up with cold / Ice spots. Keep items away from fins.
Hensley Hitch
Old 06-25-2020, 06:18 PM   #14
2019 16' Sport
Hi Peter,
The last time I looked into this I was unable to locate a thermistor and assumed it didn't exist. Today, however, I found it on the inside of the fridge. I had been looking on the outside...
Now I have adjusted it and will report back.
Thanks to you and SilverBullet for commenting.
Scott
Old 06-25-2020, 07:04 PM   #15
Thanks for the update . . . had you checked the search results in Post #3?
Also, either your AS owner's manual or the Dometic instruction book in your AS briefcase should reference the thermistor someplace IMO.
Good luck,
Old 07-02-2020, 01:12 PM   #16
2019 16' Sport
Yes, I read the link in Post 3. Neither the AS or Dometic manual mentions the thermistor.
Moving the thermistor helped a little. Things are still freezing in the fridge, but not as hard.
I'll contact AS, etc.
Old 07-26-2020, 01:01 PM   #17
2019 16' Sport
I just did a 3-night solo trip with the fridge pretty empty. Nothing froze, suggesting that it might be an air circulation issue.
An interior fan is ordered...
Old 07-26-2020, 02:52 PM   #18
Thanks for the update. It helps to have a good quantity of "thermal mass" in both the fridge and freezer to dampen the extreme temperature swings of this very simple [ . . . and "dumb" in anthropomorphic terms . . . ] machine. An empty fridge will usually freeze things at times, even if it is adjusted well IMO.
Blocks of pre-chilled blue ice in both locations work great, as do bottles of cold water in the fridge . . . anything to even out the internal temps. A small bag of ice works well in the fridge also [sitting in a pot/bowl to contain the inevitable melt water -- after the melt, put the still-cold bag in the freezer to re-freeze . . . ].
It sounds like your thermistor adjustment did the trick . . . now to just even out the temperature swings with some [already-cold] thermal mass.
Old 07-26-2020, 03:08 PM   #19
2017 28' International
Jim Falls , Wisconsin
Yep. Even with a thermostatic controlled fridge you need a fan, because there are colder spots. You can get expensive ones or inexpensive one. I bought a portable that was about $20. It just does enough to circulate air and keep the temp even.
Daquenzer is offline   Reply With Quote
Old 10-10-2020, 06:49 PM   #20
2019 16' Sport
Fan fixed it.
I bought a small interior fan, and the freezing seems to have stopped. Many thanks to all for your input!
Scott
Fridge too cold LINDAMART General Interior Topics 7 05-23-2015 07:36 AM
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 07:03 PM
Fridge too cold & Freezer door ? egad Refrigerators 6 06-05-2013 10:47 AM
Fridge too cold? 2PNPOD General Repair Forum 7 05-10-2013 07:53 PM
Refrigerator too cold wingfoot321 Refrigerators 1 09-08-2003 10:13 PM
