Crack the flared fitting at the frig gas valve till you smell gas. This proves you have gas at the frig. Then try to light. It is safe to light with a match. If match will light it does it stay on? If not the proof of flame probe may not be in the flame or bad. loosen the connection at the gas valve and retighten to make a good connection. Try again.
Sometimes spider nests or stink bugs will get in the burner tube and cause no flame or poor flame.
2004 Excursion 4x4
