Old 07-19-2017, 12:19 AM   #21
Registered User
2016 25' Flying Cloud
Fairfield , California
Fridge does not need to be on for fan to run.
Originally Posted by mikeinca View Post
I have a twist on the OP's original question. Is it normal for the refrigerator fan to run even when the refrigerator is turned off?
I read somewhere that the fan circuit is powered independently from the refrigerator which might explain why it can be on even with the fridge turned off but like I said, I never noticed it doing this before. I'd like to verify that I haven't inadvertently screwed something up or that the thermistor hasn't just coincidentally failed. Any insight would be appreciated.
No you did not screw anything up. The other day when the temps were 100+ I went into the trailer and turned on the battery power I heard the fridge fan come on even through the fridge was turned off. Today when I was in the trailer again in 80 degree weather the fan did not come on. 15 minutes after turning the fridge on to get ready for my trip tomorrow it came on.
What is the temp the switch is set at to come on?
Matti
Mattirs is offline   Reply With Quote
Old 07-19-2017, 10:24 PM   #22
CruizinDux's Avatar
Washington , Missouri
Matti
I can't speak for all AS models, but in our 20, the fan switch (by the door) is a separate circuit from the refer buttons. I think one of richw46 threads mention it. Seems 105, maybe 110 is the on and 85 is the off.
Here ya go...post 32
http://www.airforums.com/forums/f425...-134012-3.html
thresholds probably varies somewhat by mf'r
bob
seems richw46 also posted a how to test the stat (with a fry pan and a thermo???) . Thought I'd saved it but can't locate it.
Maybe he'll see this or you could PM him.
CruizinDux is offline   Reply With Quote
Old 07-19-2017, 10:38 PM   #23
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Our 2015 23D has the the upper and lower side vents for the refrigerator space. The solitary fan installed by Airstream in the middle the top vent was totally useless in keeping the refrigerator cold. We completely blocked off the top vent and put in three fans in a metal plate. Now all the cooling air has to come in the bottom vent and pass by the cooling coils enroute to the top exit. The fridge never had a cooling issue after this modification.
The fans were wired to come on via a lighted manual switch when the Dometic fridge was in place. Now that we have a freon based compressor, whenever it comes on, a relay pulses and starts the fans until the compressor turns off.
Name:	23D Fridge Cooling fan new outside view-1.jpg
Old 07-20-2017, 06:08 AM   #24
VTSafari's Avatar
2016 27' Flying Cloud
Labelle , Florida
Switz that is a real nice clean install! If external cooling is significantly improved the refrigerator should not have to work not nearly as hard.
Bill
2016 Flying Cloud FB
2014 Ram 3500 4x4 extended cab
VTSafari is offline   Reply With Quote
fridge cooling fan is on but fridge is not running hahnstead Refrigerators 5 06-24-2016 07:34 PM
troubleshooting fantastic fan that stopped running bonginator Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-05-2014 04:42 PM
Can you operate the vent without the fan running Maggiefoss Roof Vents, Skylights & Fans 3 08-26-2013 10:15 PM
Fan Wont Quit Running? Help! CalamityJane Electrical - Systems, Generators, Batteries & Solar 12 07-23-2012 06:19 AM
Refrigerator Fan won't stop running tsunami Refrigerators 18 09-17-2007 02:50 PM
