Old 04-15-2023, 05:00 PM   #1
Zeppelinium's Avatar
1973 23' Safari
1977 23' Safari
2018 25' Flying Cloud
Palmer Lake , Colorado
Fridge controller
Along with my remote leveling parking transmitter (https://www.airforums.com/forums/f38...ks-240057.html), here's a cheap replacement for a fridge controller. Like, have you looked at the replacement cost ($300+) for one?
This controller uses a 100K NTP resistor to monitor the flue temperature, an $11 sparker, a small $3 variable DC-DC buck converter, and an Arduino Pro-mini to turn on the propane valve and provide ignition. All the usual monitoring safety features are included, making sure the propane is turned off if the fire goes out.
Zep@Charmedquark.net
Old 04-15-2023, 05:03 PM   #2
1973 23' Safari
1977 23' Safari
I have an older fridge in my '73 Safari that doesn't have a controller (it's mechanical). I'm using the leveling transmitter (see link above) to send a signal to the tow vehicle if the burner blows out while I'm towing (doesn't happen every trip, but often enough that when towing for 5-6 hours you would like to know if you need to relight the fridge).
Zep
Old 04-15-2023, 07:47 PM   #3
1973 23' Safari
1977 23' Safari
Here's the code logic:
Name:	fridge logic.jpg
Victron MPPT controller or BMV 712 Smart controller? s1000pre Electrical - Systems, Generators, Batteries & Solar 21 12-26-2021 03:25 PM
Fridge Vent and Fridge 12V DC wiring rodsterinfl Electrical - Systems, Generators, Batteries & Solar 1 05-03-2014 09:33 PM
Need Fridge...can Solar keep up with an Electric Only Fridge??? chowman2011 Refrigerators 13 05-17-2011 08:59 PM
Small fridge to large fridge ? 4tumbleweed Refrigerators 3 07-04-2010 06:44 AM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
