Old 04-15-2021, 07:30 PM   #1
2021 20' Caravel
San jose , California
Fridge between trips
Hello-
I am a newbie weekender and was wondering what people do with their fridge between trips.
I recently opened mine after two weeks of non use and found it was not in the best shape. Looked like mold starting to form so disinfected and gave it a good clean.
I donít leave anything in it but some water from the freezer may have caused this.
I hgave it a thorough cleaning but should I leave it open/cracked when itís not in use?
Thanks in advance for the help.
Tnordlaw is offline   Reply With Quote
Old 04-15-2021, 07:48 PM   #2
Kevin245's Avatar
Refrigerators can get funky when closed and turned off. We empty ours and prop the door open when not in use.
William C. Swinney
Kevin245 is online now   Reply With Quote
Old 04-15-2021, 08:30 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
An open container of baking soda also helps to keep things fresh, as well as leaving the door slightly open. We normally keep the fridge running and the trailer plugged in to 30 amp when at home.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1976 31' Gone but fondly remembered
1976 22' Argosy
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 04-15-2021, 08:50 PM   #4
2018 19' Flying Cloud
Newport , Washington
At the end of a trip we wipe the inside of the fridge and freeze down as best we can and leave the door propped open and let it dry out for a day or two. As the freezer warms up there will likely be condensation. After a day or so I dry it good and clean out any spillage etc. We leave the door propped open until we are ready to use it again,
Dale & Jane
2018 Flying Cloud 19
2003 Dodge Ram 2500 Quad Cab Diesel
KelloggKid is offline   Reply With Quote
Old 04-15-2021, 09:04 PM   #5
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Tnordlaw - you should have received two door airing props (one each for the upper and lower doors) when you picked up your new trailer. Many people (sale staff included) don't know the purpose of these parts and they often get overlooked or discarded. There are prop variations (matched to different refrigerator models/vintages) but I chose this link as one that likely matches your new unit. Match the refrigerator model number to acquire the correct props.
https://www.ebay.com/itm/324511364363
De-ice and clean out your reefer after each trip; wipe down the interior with a dilute mixture of vinegar and water, place an open box of baking soda or a sock filled with ground coffee beans inside, and use the aforementioned airing props to close and latch doors which will then remain open a crack for ventilation.
https://www.youtube.com/embed/30mSEmQvk1U
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 04-15-2021, 10:43 PM   #6
2021 20' Caravel
Appreciate all the advice. This is good to know
Winterize between trips when temp drops below freezing? kwintone Winter Living 15 11-11-2020 08:35 PM
Breaker trips when fridge is on. Free range General Repair Forum 2 05-26-2019 08:50 AM
Temp storage between trips? kfrere Airstream Lifestyle 5 06-20-2015 07:16 PM
Distance between fridge burner and water line? mimiandrews Refrigerators 1 04-09-2009 11:53 AM
First Trips COLORADO_CAMPER 1997 - 2004 Bambi 5 07-18-2003 11:42 AM
