Originally Posted by Chrishall
I have never used my fridge on propane. Is there a way to tell if the fridge lights when LP selected, other than waiting for it to cool?
Yes, stand outside the lower vent while someone turns it on and you will hear it clic clic clic clic then a faint sound of a flame, similar to the water heater but very faint in volume, it has to be pretty quiet for you to hear the flame. If it fails to light it will attempt several times before locking out. Mine is close enough to the door that if the door is open I can hear the clic clic clic.
You can also remove the vent and peek in, there is usually a sight hole in the tin box at the bottom of the heat tube where if you are looking at the right angle you should see a small blue flame.
Once it starts you will feel cold on the freezer fins pretty quickly, although it will take hours to cool down the fridge, the freezer gets cold first.
