Old 04-08-2023, 03:17 PM   #1
2000 25' Safari
Ishpeming , Michigan
Freezer is building up layer of ice/ frost
Also icles starting on refridgerator vent.Note: the trailer is not Level
Letch is offline   Reply With Quote
Old 04-08-2023, 04:52 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 199
RE: Refrigerator/Freezer Frosting Up & Trailer Not Level
Greetings Letch!
From your user profile, it appears that your Airstream is a 2000 model which would mean that your refrigerator is likely a Dometic two way LP Gas/120-Volt AC of the absorption type. While it is likely new enough to have electronic controls (assuming that it is contemporary to trailer), it is still of the era that will protest in a variety of ways when operation is attempted in an off-level condition. The best place to determine level with these older absorption refrigerators is with a bullseye level placed on the freezer floor. When the bubble is dead center is when the refrigerator/freezer can be depended upon to be most efficient and least likely to run overly warm or overly cold.
If it were just the refrigerator temperature, the sliding sensor at the back of the refrigerator would be suspect for need of adjustment. With my 2000 era Dometic Americana, I believe that this sensor needs to be pushed up on the fin to lower the temperature or pulled down on the fin to raise the temperature in the refrigerator, but I may have that reversed as I haven't had to touch it in a number of years.
Another possibility if the trailer is new to you, is that the door gaskets may be worn allowing air to enter. Leaky door gaskets and camping in a humid or rainy location can result in excess frost accumulation.
Good luck in locating your refrigerator's issue.
Kevin D. Allen
WBCCI (Lifetime Member)/VAC/Pride Streamers/Wisconsin-UP Unit (Primary)/Missouri Greater Ozark Unit (Affiliate Member) #7864
AIR #827
1964 Overlander International
Old 04-08-2023, 05:04 PM   #3
2000 25' Safari
Great info.thanks for taking the time!
Old 04-08-2023, 08:25 PM   #4
AKNate's Avatar
2018 30' Flying Cloud
Anchorage , Alaska
That is normal. These type fridge/freezers don’t have a defrost cycle like your one at home. The longer you use them the more frost builds up until you manually defrost. The more humid the climate and the more you open/close the fridge the faster it will frost up.
AKNate is offline   Reply With Quote
Old 04-08-2023, 08:50 PM   #5
s1000pre's Avatar
2021 30' Flying Cloud
2020 25' International
minneapolis , Minnesota
Get one of these for the fridge/it works great!!!
RV Refrigerator Fin Fan https://www.amazon.com/dp/B089BWZ3PX...p_mob_ap_share
Freezer: As AKNate said, icing is normal, and it will occur quicker in higher humidity. Wait until you can’t live with it any longer, and follow the following process.
Also: make sure you are connected to shore power. It will take 12-24hrs. for the freezer to cool back down. Leave the refrigerator closed during the following process to keep the items in the fridge cool.
1. Scrape as much of the frost out as possible. A plastic spatula like a good grips, or credit card works well.
2.Turn off power
3. Place pot of boiling water on a towel inside the freezer, then close the door.
4. Wait 25-30 minutes, open door and wipe dry
5. Turn power back on and wait for the freezer to cool.
The items in your refrigerator will be fine since you won’t be bringing the fridge up to temp. It won’t be any different than loosing power for 40 minutes.
- Stewart
s1000pre is offline   Reply With Quote
heavy frost on refrigerator fins Geno48 Refrigerators 5 08-08-2022 04:34 PM
Ice maker/freezer built in mayco Airstream Classifieds 0 08-09-2017 03:37 PM
Frost in my fridge jump Refrigerators 31 03-18-2016 09:16 PM
Ice, ice Baby! hippiechick General Repair Forum 1 03-12-2015 06:42 PM
Frost on Freezer Door? glacierrunne Refrigerators 1 09-11-2008 10:41 PM
