Originally Posted by DEITZ645
dznf0g,
I contacted Dometic about the lack of a flue baffle and this was their response...
So does yours have one. I believe yours is the newer version of the one I had in my old SOB. I can't remember the exact model number but it was a fully manual 6 Cubic Foot Dometic. It had a baffle. I don't think the cooling unit is any different...just not automatic in switch over nor ignition.
Check out my previous post on the movement of the thermistor. That was the final resolution...but that unit had a baffle as does my present fridge. I know, because I had to switch it out of my old cooling unit to my new cooling unit this spring when all the yellow stuff came out.
Are you the original owner and is this the original fridge/cooling unit?
Pull up a parts list for your model and see if it shows a baffle.
