ok the 3 screws on bottom kept coming loose while traveling down road. Is there a way to remove the door so I can see whats going on in threads. If I can get this off and make sure there biting down, blue loc tight on screws.
once I used thin string to pull knobs off the unit came out top. Then I could see 10mm on top and below the door. Comes off pretty easy, remember the washer and nut on bottom part door.
