Old 07-07-2021, 05:14 PM   #1
1964 19' Globetrotter
Val des monts , Ontario
Dometic removal rm461
Hi
Does anyone know how the fridge is fasten in a 1964 Globetrotter ? Iím trying to find all the screws thatís holding it in place ?
Thx
roots78 is offline   Reply With Quote
Old 07-07-2021, 06:40 PM   #2
1966 22' Safari
Fredericksburg , Texas
If itís anything like the original fridge in our 66, it can be removed with a little effort. Ours sits on a couple of small rails attached to the bottom of the fridge. The rails have screws into the subfloor. If you access the bottom through the outside access hatch, you should be able to feel the screw heads. I also think there are a couple of screws along the front side corners through the inside of the short bulkheads. This is probably as clear as mud. Good luck
Bubba L is offline   Reply With Quote
Rivet Removal Tool OR Blind Rivet Removal T mkamanu General Interior Topics 3 10-12-2015 07:29 PM
AC removal before interior wall/shell removal? TexasAir67 Exterior Restoration Forum 1 07-25-2013 07:58 AM
Dometic removal mmenchel Refrigerators 0 10-04-2010 04:19 PM
Cabinet Removal - Closet Removal 2333 Cabinets, Counter Tops & Furnishings 2 10-05-2006 01:00 PM
dometic RM75 removal userypark Refrigerators 2 10-01-2006 07:27 PM
