Old 05-26-2024, 02:11 PM   #1
2011 23' FB International
Jackson , Wyoming
Dometic refrigerator fuse issues
Nothing too exciting or sexy about this problem. The fridge in our 25' International Serenity (FBT) has blown the glass fuse (twice) on the electric panel reached through the exterior hatch. The fuse apparently is protecting the heater element.
Dometic: RM 3762 or RM 3962 is the fridge model as indicated by the manual that came with our 2019 trailer (purchased in 2021).
The good folks at the nearby Airstream repair shop have replaced the fuse both times and say the panel will be next. They also estimated a new Dometic would set us back 2k, an expense I would clearly prefer to avoid.
Your thoughts and expertise would be appreciated.
BTW, I've been told these glass tube fuses (5 amp?) are very hard to get and are very expensive so if you know of a source, I would appreciate that too.
gzeigler is offline   Reply With Quote
Old 05-26-2024, 07:53 PM   #2
1988 32' Excella
Robbinsville , New Jersey
Many people use dinosaur boards and say they are better then OEM.
You can get fuses from Amazon.
https://www.amazon.com/AMPELE-Pack-F...17649663&psc=1
Old 05-26-2024, 09:18 PM   #3
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
I needed a board for my RM3962 and contacted Dinosaur, and they told me that they do not make a board for either the RM 3762 or the RM3962. Only place to get one is Dometic. Last time I checked they were over $400, so I have been running my fridge on propane. I talked to Dometic last fall and they had no boards in stock and didn't know when they would have them.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 05-27-2024, 08:30 AM   #4
Jackson , Wyoming
As usual I received very helpful responses. I now have a source for fuses and a workaround. Thank you.
gzeigler
Old 05-27-2024, 12:00 PM   #5
RJJ
RJJ's Avatar
2016 26' Flying Cloud
2016 20' Flying Cloud
St Petersburg , Florida
Can this fuse be used also?
This is a slow blow fuse as opposed to a fast blow fuse. It's 30 amp vs 5v.
https://www.amazon.com/dp/B00GZOIR1O...v_ov_lig_dp_it
RJJ is offline   Reply With Quote
Old 05-27-2024, 04:02 PM   #6
1988 32' Excella
He said his fridge fuse is 5 amp switching to a 30 amp could be dangerous.
Old 05-27-2024, 07:36 PM   #7
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
They put a 5 amp fuse in for a reason!! That is what is required!! A 30 amp is asking for a disaster!! Ask any electrician!!
ACI #7394
1994 Excella 34'
Hensley Hitch
Old 05-27-2024, 09:44 PM   #8
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
If the fuse is protecting the heater element and keeps blowing, then perhaps your heater element is what's bad.
Test the heater element and then inspect the power circuit leading to/from to make sure you don't have a short.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Old 05-28-2024, 05:46 AM   #9
RJJ
RJJ's Avatar
Ah. My error... FSR I read 5v stead of 5amp...
2016 Flying Cloud, 26U! REX
2018 Tundra Limited, Attitude Black, The Princess Behemoth!
2016 Flying Cloud 20, REX, gone but never forgotten.
Old 06-02-2024, 12:57 PM   #10
MMCMRET's Avatar
2021 25' Flying Cloud
Fredericktown , Ohio
Thanks for the post which has spurred another question. Does anyone have a good link for the small, 30A, pointed blade fuse that goes into the back of the Dometic Gas/Electric refrigerators? My model number is DM2672RB. Thanks in advance.
Todd Mizer
2021 25' FBT Flying Cloud
Ford F-250 6.7L
WBCCI #6826
We have Year-Round Courtesy Parking.
MMCMRET is offline   Reply With Quote
Old 06-03-2024, 07:03 AM   #11
Jackson , Wyoming
Thanks to Wazbro I found the 5 amp fuses on Amazon. Turns out coincidentally my Airstream shop nearby is now doing the same. So, I recommend you start there.
Info For Dometic AC and Dometic Refrigerator faberm Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-01-2023 08:05 AM
Fuse remover, fuse set, light Vitaver Electrical - Systems, Generators, Batteries & Solar 1 10-30-2022 01:04 PM
69 dometic refrigerator issues. 69bullet Refrigerators 9 11-11-2020 11:01 AM
Fuse Issues - 2017 Airstream Interstate Charleston40 Sprinter and B-van Forum 1 08-27-2020 04:37 PM
Refrigerator issues Dometic RM2811 Vac time General Repair Forum 4 07-28-2013 06:08 PM
