Old 02-27-2018, 09:43 AM   #1
2017 25' Flying Cloud
Raleigh , NC
Dometic Refrig Door Heater Cutoff Switch Install?
We have a ‘17 FC. I am thinking of adding a cutoff switch for the door heater. Based on the diagram on the unit, it looks like it is labeled T? If so, how do I find P5, is it the light blue cable in my photo?
ID:	305097   Click image for larger version
JoeHTP is offline   Reply With Quote
Old 02-27-2018, 10:56 AM   #2
LAWBC's Avatar
2013 27' FB International
2012 23' Flying Cloud
GVA , British Columbia
Fridge switch?
Interesting but I don't believe that your fridge has a door heater but you do have a fridge light that does stay on to regulate the unit to run when outside temp is cooler to force the fridge to cycle ( introduces heat) .
It appears "T" is the heater element to run the fridge on 120volt .
Question , why do you want to introduce a cut off switch ?
Laurence
LAWBC is offline   Reply With Quote
Old 02-27-2018, 11:48 AM   #3
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Door Heater Cutoff Power Saving
By placing a disconnect switch for the door strip heater saves 1/2 the power (ah) of the fridge operation. VERY desirable when boondocking as this is on 24/7.
This added switch (usually put right at the inner fridge light interrupting one thicker of the 2 black wires) Saves approx 9ah a day. This equates to all the usable power 12volt 80ah bat over 4days use.
We did and happy to save stupid power draw.
An excellent mod to do !
Vantair is offline   Reply With Quote
Old 02-27-2018, 12:01 PM   #4
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
It is item T. On my fridge it is wired from the light that comes on when the door is opened. You can't get to it from the back. If you cut the wire in the back it will also kill the light.
Vantair has it right. Put a switch at the light. One light terminal has two wires on it. One is 12V, the other goes to the heater. You may have to experiment to find out which wire it is. Disconnect them both from the light and the one with 12V on it goes back on. Wire a switch between that one and the wire that goes to the heater.
Al
Al and Missy is online now   Reply With Quote
Old 02-27-2018, 12:06 PM   #5
Raleigh , NC
Thanks everyone for the great info. I want to do it for the reasons stated here by the others, save some amp hours during boondocking, as it is probably unnecessary in cold climates or hot/dry ones.
Any suggestions for a particular switch type/photo of an install?
Joe
Old 02-27-2018, 02:00 PM   #6
Vantair
Vantair's Avatar
Joe
Hi Joe,
Yes, see below link. 4 pieces for $5.54.
(Sorry, have full pics and install info but just now out of Airforum pic space). Mount switch internally facing fridge door on the inner light switch assembly on the downward angled plastic face down low. Careful to allow clearance of newly added switch terminals and nearby fridge light terminals. Told the “larger black wire” at the fridge light should be the one to the door heat strip. Was the case with ours.
Uxcell a15062200ux0651 2 Position 6Pins DPDT ON-OFF Micro Mini Toggle Switch, AC 6 Amp, 125V, 4 Piece https://www.amazon.com/dp/B015DLW0EE?ref=yo_pop_ma_swf
Old 02-27-2018, 03:37 PM   #7
Raleigh , NC
Thank you!
Old 03-01-2018, 09:27 AM   #8
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
Hi Joe,
Vantair,
Thanks for the information, but why is a DTDP (Double Throw Double Pole) switch needed? It sounds and looks like the switch only needs to be installed in the heater line so a STSP switch ought to work, and be smaller.
BillfromWI is offline   Reply With Quote
Old 03-01-2018, 11:11 PM   #9
Vantair
Vantair's Avatar
Door heater switch
Originally Posted by BillfromWI View Post
Vantair,
BillfronWI,
True. Single throw single pole SPST is all you really need but for approx same size/almost same price this unit is “actually” a similar 1on/2off switch.
Also this double pole single throw DPST operates same method but doubling connections across now both terminals so doubles or more the current and power rating thus long term reliability.
Why not at same time of price/install effort I say.�� Making our Airstreams better. !
Old 05-30-2018, 01:53 PM   #10
Vantair
Vantair's Avatar
Dometic door heater switch install video -Saves Battery ah !
BillfronWI,
http://www.airforums.com/forums/f37/...eo-182263.html
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Old 12-03-2018, 11:02 AM   #11
2018 27' Tommy Bahama
I'm getting ready to leave on a 3 week trip, boon-docking off and on, so want to reduce my battery draw from the refrigerator heater strip.
I found an easy disconnect that appears to work on my 2018 27FB Tommy Bahama. According at the wiring diagram, the heating cable (not the 120v one) is wire T, Wire T has a 10 on the diagram which maps to color 10 - light blue.
Looking at the circuit board, I saw one light blue wire attached to the circuit board (yellow circle on pic), and another to a common ground, visible in the bottom right corder. It seemed like this should be the heater cable. I disconnected it and everything seems to work just fine.
Checking before and after amp draws on my Victron monitor, I see about a 0.8 amp reduction in battery draw when fridge is operating on propane.
Any comments?
Wiring diagram:
Circuit board.
Thanks!
David
pwlldvd is offline   Reply With Quote
Old 12-03-2018, 11:04 AM   #12
Corrected amp savings on original post to 0.8 amp savings.
Old 12-04-2018, 07:24 AM   #13
Raleigh , NC
Thanks for the continued feedback! I found the same thing...when I disconnected that cable I got about 0.8 amp per hour less draw. That is ~20 amps a day savings, a good chunk if you are boondocking. It has made a huge difference.
We really did not see any difference in refrig performance (door moisture) with it disconnected. However, since it connects via spade lugs, I bought an automotive switch with spade lugs, put lugs on both ends and reconnected the cable. Now I can just open the exterior refrig compartment and flick it on and off whenever we are boondocking.
BTW, this does not affect operation of the light.
I know others suggest putting the switch inside the refrigerator (in the light), another valid way of doing it, but I found the method I used to be quick and easy.
Dometic Refrig Door Heater Cutoff Switch JoeHTP General Repair Forum 0 02-25-2018 07:18 PM
Battery Cutoff Switch Install for 6v Batteries JoeHTP Electrical - Systems, Generators, Batteries & Solar 5 01-18-2018 01:26 PM
Battery cutoff switch contradiction - 2007 Classic dznf0g 2006 - 2010 Classic (all lengths) 0 09-29-2010 08:10 PM
Battery Cutoff Switch Silverbee Electrical - Systems, Generators, Batteries & Solar 16 09-13-2010 06:00 PM
