Old 04-01-2019, 07:46 AM   #1
dlkershaw's Avatar
2016 22' Sport
Swedesboro , New Jersey
Dometic/ Norcold / Questions
Good Morning all: For reasons I will NOT bore you with, I need replace my 4 year old Dometic RM 8505, ( 22fb Bambi) the fridge has been a problem since day one and has died, dead died..... Dometic has attempted, ( limited Help ) parts are no longer available..????
Has anyone any experience with Norcold, I am beginning a search for a replacement and I hate to reward DOMETIC for bad product and service, by purchasing from them again...
Thanks for your input: Dave
dlkershaw is offline   Reply With Quote
Old 04-01-2019, 12:48 PM   #2
2008 27' Safari FB SE
Miami , Florida
Look at a Danfoss type 12v compressor reefer. Nova Kool is one brand. Pricey but quiet and the freezer gets cold enough for rock hard ice cream...
Middle-aged (usually dirty) Nissan Titan XD
Middle-aged Safari SE
Young, lovely bride
Dismissive cat
Goofy dog
Old 04-01-2019, 02:49 PM   #3
PKI
PKI's Avatar
Walnut Creek , California
In a recent investigation of motorhomes, the subject of fires reared it's flaming head. The issue is flamable refrigerant (ammonia?). Refrigerators were suspect as the tubing that transports the refrigerant corrodes and holes develop. The gas is released and pilot/burner flame ignites it. Then there is a fire that quickly spreads. The Norcold is what was referenced. Dometic was the goto if a residential frig was not viable. Disclaimer - new models may be completely different with respect to risk. Your investigation is recommended.
http://www.irv2.com/forums/f65/norco...re-436732.html See post #5
If I had a recent vintage refrigerator, I would be talking to the manufacturer's customer service at the highest level I could contact. Maybe a better model for half price might make me happy. The Danfoss solutions are liked by some. The one in our boat was a bit noisy and spent most of it's time turned off. YMMV. Pat
Old 04-01-2019, 02:57 PM   #4
2007 22' International CCD
Not the ammonia, but there is hydrogen gas under pressure in the sealed system. That’s the nicely flammable component that gets it going...
Old 04-03-2019, 08:22 AM   #5
kidjedi's Avatar
1972 25' Tradewind
1976 31' Excella 500
1974 31' Excella 500
1975 24' Argosy 24
Denver , Colorado
FWIW, my 1969 Dometic 3 way is still going strong (ice every night!). Bummer that you had a bad experience with their new customer service dept.
25' 1972 Airstream Trade Wind Land Yacht (heavily customized)
2006 Jeep Liberty CRD (diesel)
BeahmStream.com
kidjedi is offline   Reply With Quote
Old 06-15-2020, 12:22 PM   #6
2020 23' Globetrotter
2014 22' FB Sport
East Texas , Texas
Hello. Did you ever replace your Dometic RM8505 fridge in your Bambi Sport 22? Mine has given me so much trouble I really want to replace it, but it's no longer available and I can't find a replacement that will fit in the space. Just wondering what you have done to deal with it? Thanks!
Imustwander is offline   Reply With Quote
Old 06-15-2020, 03:03 PM   #7
dlkershaw's Avatar
2016 22' Sport
Earlier Post
Imustwander, Please check your post / question, earlier today) I added a detailed response concerning my replacement. Best of luck. Dave
Old 06-26-2020, 04:31 PM   #8
NOAZRK
NOAZRK2690's Avatar
2004 34' Classic S/O
Kutztown , Pennsylvania
Dometic refrigerator oil puddle.
This thread on Dometic refrigerators seems like the place to be. I have just noticed that my refrigerator now is accumulating a puddle of oil type substance under gas burner area. Any ideas where this is coming from and what it means?
NOAZRK2690 is offline   Reply With Quote
Old 10-19-2021, 10:39 AM   #9
breton's Avatar
2014 22' FB Sport
South Shore , Massachusetts
Rm 8505
Mine just crapped out too. Maybe the RM2354. I'll let you know. Shop can't take me until the end of Nov.
What did you end up with?
breton is offline   Reply With Quote
Old 10-20-2021, 11:26 AM   #10
dlkershaw's Avatar
2016 22' Sport
Rm8505
Sorry to hear of your issue,
I was able to locate a new replacement in a warehouse in Indiana. The parts manager at a local Camping World worked to locate one.
My understanding is they are no longer making the model.
Also, I believe they no longer manufacture the 3 way ( propane, Battery & Electric). You may locate one somewhere, keeP searching and good luck.
Old 10-21-2021, 07:05 AM   #11
NOAZRK
NOAZRK2690's Avatar
In another thread I detailed with photos how easy it is to install a new Amish made cooling unit onto your existing refrigerator box. If your reasonably confident with a screw driver and a small socket set, check out this option. The Amish have redesign the boiler chamber so it's better then new. My 2004 Dometic refrigerator, fitted with a new self contained cooling unit is amazing. On position 3 (mid range) setting my refrigerator averages 36 degrees and the freezer is at -5 degrees, consistently through the heat of the summer. When I removed my old refrigerator coil, I could see where the electric heating element burnt through the coil then compared that to my new coil. There was a redesign and reinforcement in that area. Don't let the wiring scare you from this project. Take lots of photos and tag your wire locations/connections.
https://www.arprv.com/amish-cooling-unit.phpClick image for larger version
ID:	406688Click image for larger version
ID:	406689Click image for larger version
ID:	406690Click image for larger version
Dometic vs. Norcold Globie64 Refrigerators 8 10-20-2009 06:18 PM
Norcold N841 IM Replacing a Dometic RM 1303 AES vswingfield Refrigerators 6 01-19-2009 06:09 PM
Norcold vs. Dometic biggoofball Refrigerators 18 06-06-2008 10:21 AM
Dometic or Norcold JimGolden Refrigerators 8 07-02-2007 11:37 PM
Fridge: Dometic Vs. Norcold AYRSTRM2 Refrigerators 7 04-17-2006 10:57 AM
