Freezer door springs
I just fixed mine, and it was not the spring failing, but rather the housing in the side wall that holds the spring had failed. Originally a 1/16th inch hole had been drilled in to this housing which locked down the end of the spring. I drilled another hole 90degrees from the original hole, put it back together and it works like it is supposed to. I was able to remove the housing by using a thin putty knife and working around the base, yes they were glued in but mine came out with out damaging other parts.
