Originally Posted by Gibson3798
After changing LP tanks to refill the one that I was using, everything seemed good until I saw the temp on the fridge was reading 60 and flashing LP.
We are on shore power and I think it must have something to do with changing the tanks and switching to the new tank, which had never been used (2020 FC 25ft.).
Stove works perfectly. Confused, seeking input. Thanks
Do you have the fridge set to LP-only? On shore power if it's in Auto it should be using electricity and not checking for LP.
Check that the fridge is in Auto.
Check that all your 120v breakers are closed.
Check to see if the plug in the exterior fridge compartment is securely plugged into the receptacle.
As far as the LP part goes: Once you exceed it's timeout for lighting the propane, you have to turn the fridge off and on again to get it to try again on the LP.
