Old 10-03-2021, 04:39 PM   #1
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Caulk
13 31’ Classic..I pulled my refrigerator out to access the solar pre wires…what caulk did airstream use on the bottom to seal the compartment.?
Old 10-03-2021, 05:58 PM   #2
dznf0g's Avatar
Oswego , Illinois
Dont.know, but mine was white. I dont think it matters a lot which you use.
-Rich-
Old 10-04-2021, 06:17 AM   #3
"Cloudsplitter"
Welcome Aboard👍
I use this a lot on the AS and most everything that needs it.
Old 10-04-2021, 06:39 AM   #4
richard5933's Avatar
1994 25' Excella
Waukesha , Wisconsin
There are a few caulking products recommended in various threads. I used Volkum polyurethane with good results to seal under my fridge .
Try to avoid silicone products though, as once you use them you're locked in with silicone as nothing will stick to it. I've also not found it to last as long as polyurethane caulk.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
richard5933 is offline   Reply With Quote
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
caulk removal Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 10-17-2002 08:56 AM
