Old 09-09-2023, 04:12 PM   #1
2019 30' Flying Cloud
Liverpool , New York
Boondocking Newbie
We just tried camping without hookups and our refrigerator didn’t last 24 hours. We’re not sure what we did wrong. We have a 2019 30 ft Flying Cloud. I don’t think we have solar. We thought the fridge would run off of the propane? Clueless.
NewAirOwner is offline   Reply With Quote
Old 09-09-2023, 04:25 PM   #2
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
It will run on propane if it is designed to do so and if you set it to run on propane. And you have propane in you tanks.
Have you checked the owners manual?
You can also check the control panel when you open the door. Does it shoe a flame as one of the options?
Old 09-09-2023, 04:33 PM   #3
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
Well, your refrigerator should easily last 24 hours if it's running on propane. Possible reasons why it didn't:
1) Your batteries were already run down. Even when running on propane some 12V power is required.
2) You're out of propane or the valve which should automatically switch between tanks when one is empty is faulty. Also, it's possible that the transfer valve tried to switch to the second tank and the supply valve on that tank was turned off.
3)You've selected the wrong operating mode for your fridge. I'm not sure if the 2019 FC has a 2-way or 3-way fridge. If it's a 3 way and you have 12V operation selected it will run down the battery in a hurry.
4) The fridge is broken or not operating properly.
Do you have the standard batteries that come stock from Airstream? Also, you say you don't think you have solar. If you're not sure, find a place where you can look down on the roof of your trailer. You'll either see solar panels or not.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
As newbie as newbie can get! wdpalmer Member Introductions 16 02-16-2023 11:01 AM
Newbie questions about boondocking switters Boondocking 55 09-17-2020 03:53 PM
South Crushed boondocking dreams. Need Generator Help- newbie Erika_C Boondocking 47 07-14-2020 12:26 AM
Newbie Boondocking In Washington State Bradley G Boondocking 12 06-08-2018 07:53 PM
Newbie help request from Newbie southsaglejim Plumbing - Systems & Fixtures 18 09-10-2014 07:39 PM
