05-06-2025, 07:47 AM
2018 19' Flying Cloud
Eugene
, Oregon
12v Fridge Battery Drain?
I was hoping to hear peoples experience with the new 12v Fridge and its impact on battery drain when boondocking. We await our new 20' trailer that has 200w solar and lithium batteries, but have heard there might be issues with how much drain the 12v fridge has on the batteries. Will the 200w solars be enough? Our 2015 trailer ran on propane, which I prefer, but I am a bit concerned with the limitations - if any - with the new 12v fridge. If people have experience with it, or any tips, I'd love to hear them.
05-06-2025, 07:57 AM
2019 22' Sport
Port Coquitlam
, British Columbia
If it is a Dometic 3 way fridge like ours in our 2019, you can run it on propane and the battery usage is low at that point.
Full 12V by itself does consume a lot of battery reserves.
We have no problem running ours for long periods of time on propane off grid.
When we are driving, I run the 12V only and do need to get the battery back up once we are parked, by switching back to propane
Peter.
"Live Long and Prosper \\//" - Spock
05-06-2025, 08:47 AM
2006 25' Safari
St. Augustine
Expect one lithium a day to be drained by an 8 cu ft model. I have done the math on the Norcold and the Dometic. They are about the same. If you are a boondocker, you will either need a bank of batteries and a generator and roof of batteries or a propane fridge. The propane one I have will run 28 days on one 30# tank.
Some people were suckered off propane by comparing the 2 way electrical comparison- not its native propane energy source.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
05-06-2025, 08:57 AM
2007 19' International CCD
Somewhere
There are many, very informative, threads on this topic. The “search” function is your friend.
In summary, they are power hogs, require minimum 3-400 watts of solar panels, and if solar conditions are not good (cloudy or shaded site) will still require a generator to get you past a couple of days.
05-06-2025, 09:08 AM
2023 25' International
Alameda
I have the 10CF 12v fridge and reports of it's energy consumption on this forum are greatly exaggerated.
If you leave it at a reasonable temp and do not open it excessively and use night mode you can expect not a huge amount of energy use.
Back when we only had 300W of Solar , as long as the sun was shining during the day, electricity was not our limiting factor for the length of time we could boondock. Waste water was the limitation.
05-06-2025, 09:26 AM
Tio Oso
2021 22' Caravel
Woodstock
, Connecticut
2021 Caravel 22' with the tiny, 12V reefer. It draws 1 to 5 amps depending on cabin temp and times we open and close. Averages 1 to 2 amps this Spring. We don't have lithium and only rooftop panel. We get 2 days before I get nervous about the battery voltage.
05-06-2025, 10:50 AM
Half a Rivet Short
2022 Interstate 24X
Carlisle
, Pennsylvania
Hi
Depending on where you are, your 200W panels may give you anything from zero AH in a day to quite a bit more. 20 AH a day would not be all that unusual in the northwest.
Your lithium batteries are probably 200AH. If they start out at 80% charge you have 160 AH to use.
It's a good bet that you will use at least 20AH a day on "other stuff" while out and about. (The fridge is not the only load ....).
Depending on temperature and a few other things, your fridge probably pulls between 2 and 5 AH an hour. In 24 hours it will use 48 to 120 AH just for the fridge.
Worst case scenario: you are in trouble in under 2 days. This includes drive time if you do not have a DC/DC converter.
Best case, you might make it a couple of days.
05-06-2025, 11:47 AM
1994 25' Excella
Waukesha
, Wisconsin
Sounds like you're talking about running a 3-way fridge from 12vdc. Running one of the new compressor 12vdc fridges from 12vdc is not at all the same thing.
The one we had in our motorhome would consume about 50-70 amps a day, so your solar should be able to keep up if you don't have a lot else running.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
05-06-2025, 11:58 AM
BarrettArt
2023 27' Flying Cloud
Silverthorne
12v fridge
I have the 12v, too, and it definitely compromises my ability to boondock. I have 500w solar but even with bright sun, the fridge drains the battery in just three or 4 days. 12v does get colder faster and stay colder, but that’s the tradeoff. I wish I had my propane fridge back.
05-06-2025, 12:35 PM
2023 25' Globetrotter
2021 16' Bambi
Forest Lake
I'm on the side of the "12V refrigerator is not as bad as people want to make it out".
Anecdotally, we have 300W on the roof but a larger refrigerator than yours in our 25' GT. We bent an axle and had our trailer sitting at the trailer shop for a month with the refrigerator running in June in Minnesota. When we picked up the trailer the batteries were at 90% and my beer was very cold.
So, I'd try it out and see. Park it in the driveway unplugged and see how it goes. If your panels are in the sun then that's likely best case. We have ours set to where ice forms in the freezer solid but barely, so not full blast. Be sure to sample a beer every day, but a margarita party with the neighbors might be too much.
We have 4x100Ah lithium with 300W on the roof and 420W external plug in panels. Boondocking with Starlink, frig, computers, etc. we haven't run out of electricity or even come close. We watch our consumption and are frugal. But as stated above tanks are the limiting factor.
Some things to consider: - As stated above, a DC-DC converter hooked up to the 7-pin charge line will help a lot between destinations (if boondocking on arrival). It's like having an extra 200W panel.
- Plug-in external panels are almost better then the rooftop since the roof is shaded often.
2023 Globetrotter 25FBT "Curly"
2017 Audi Q7 3.0T
WBCCI 6343
05-06-2025, 03:23 PM
2022 33' Classic
Chesapeake
, Virginia
We like our 12V 10 cu ft Norcold. We can boondock just fine with 400Ah lithium, just run the generator late in the day. We've never reached 50% SOC, even after morning coffee, microwave use, etc.
05-06-2025, 04:16 PM
2022 23' Flying Cloud
Mobile
, Alabama
I wonder how much, if any, a block of ice in both the freezer and refrigerator compartment would help?
Imagine taking a couple of ice cube bins, filling them with water and freezing it at home. Put one in the fridge, and one in the freezer.
05-06-2025, 06:07 PM
2018 Basecamp
Fairview
, TX
Our frig in our 2024 BC20x works great especially when compared to our 2018 BC16 frig. The Dometic in 2018 BC16 in the summer was barely functional.
05-06-2025, 08:32 PM
2019 22' Sport
Port Coquitlam
, British Columbia
Yes, I was thinking that propane flame would just blow out while travelling so I switch it to 12vdc. I have a 250ah lithium battery so it does well but will show a good drop after lots of travelling.
I guess I could run it on AC as well just by switching on my inverter but I expect that this would just use more power than straight DC.
Peter.
05-06-2025, 09:57 PM
1994 25' Excella
Waukesha
, Wisconsin
This thread is about using a modern 12vdc compressor fridge, not a 3-way propane fridge.
That said, neither the 120vac or 12vdc options for a propane fridge are anywhere near as efficient as running it on propane. Just run it on propane while traveling and you'll be fine.
You can use the search function to find many existing threads on the use of 3-way fridges while traveling.
Richard
11018
05-07-2025, 09:04 AM
2016 28' International
Trois-Rivieres
, Quebec
Wally Byam used to say, let's not make changes, let's make improvements.
Maybe we could go back to this technology as an improvement.
2016 International Signature CCD, RBQ, Dual A/C, 28'
2018 GMC Sierra SLE 2500HD, 4x4, Crew Cab, Duramax Diesel, Leer cap
Lift kit, 16" wheels, Michelin Agilis CC LT
DIY Solar: 500W Renogy panels, AM Solar hdw, Blue Sky MPPT controller, 470ah Rolls battery bank, 2000W Renogy inverter.
05-07-2025, 09:13 AM
2019 22' Sport
Port Coquitlam
, British Columbia
Hi Richard, I lost that part in hurry to write a response to the OP. Sorry for the attempted derail!
It would seem that this new modern fridge design is leaps ahead of the rest to the trailer tech! Perhaps a little generator or beefed up solar/battery would be needed to keep the boondocking situation workable?
Peter.
05-07-2025, 09:39 AM
Somewhere
The post above that says with 400Ah of lithium batteries they still run the generator every day shows what you are up against. Also, some of the experiences posted omit the ambient temperature, which is essential information. The duty cycle you will experience is critically dependent upon ambient temperatures; at 70 degrees a 50% duty cycle is a reasonable expectation, but in the 90’s with warm nights you will be closer to 90%, or double the usage.
05-07-2025, 09:40 AM
1985 25' Sovereign
Navarre
, FL
We have a Norcold unit that draws about 5 +- Amps when running and it is a little less than 50% duty cycle.
That averages about a 2.5 Amp continuous load on the system
We have 600 watts of solar on the roof and that does a pretty good job of charging the 300 Ah battery system. That consists of 3 100 Ah Chin's batteries in parallel.
The Victron Smart Shunt (which I highly recommend) tracks the usage of power and the voltage and current etc of the system pretty well.
I find that the basic 12 volt loads as minimal and the refrigerator is the major night time load that needs to be replaced by the solar cells. That accounts for around 12% of the available power per night. We also have the TV and lights etc on 12 volts and there is a 2000 watt inverter to power an induction hot plate and the microwave (not used much).
I believe that the LiFePO4 batteries will easily power the trailer for several days with poor sunlight. With poor charging we do regain a little power stored, but don't necessarily get back to 100 percent.
One thing to remember is that you can discharge the LiFePO4 batteries very much lower than the lead acid batteries without damaging them.
We have a Progressive Dynamics PD-4560 that will recharge at 60 amps to recharge the batteries from either shore power or the small 2200 watt LP or gasoline generator we use. The batteries will recharge at a pretty high rate (up to the max available from the charger up to 300 amps ( 3 x 100 Ah batteries) so a good charger helps limit the length of time the generator has to run to recharge the battery bank.
If you have a single 100 Ah battery the refrigerator will use about half of the charge, two batteries about 1/4 of the charge and three about 16% etc. overnight.
Your mileage will vary...
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
already have 12v fridge, want to install 12v AC unit, and have new lithium batteries
starkruzr |
Batteries, Univolts, Converters & Inverters |
2 |
04-19-2024 04:38 AM |
12v fridge-replace 120/propane with 12v
SilvaStreama |
Refrigerators |
21 |
06-11-2023 08:16 AM |
Can I replace 12V AGM battery with 12V deep cycle battery?
iainmcc |
10 |
06-06-2020 08:05 AM |
12V battery power drain
jdlimages |
7 |
02-02-2015 02:01 PM |
Fridge Vent and Fridge 12V DC wiring
rodsterinfl |
Electrical - Systems, Generators, Batteries & Solar |
1 |
05-03-2014 09:33 PM |
