We are on our maiden voyage in our 2023 globetrotter. The 12volt electric only compressor fridge won’t stay below 44 degrees. We tried defrosting. Still not doing the job any ideas? Thanks
How long was it on prior to starting your trip? Did it get down to 40 before you loaded food in, or did you load products in while it was still cooling?
What’s the outside temperature?
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
It should definitely be able to stay cooler than that. Check the ventilation around the fridge to be sure that the places for air flow are clear. If that isn't the problem, it sounds like a warranty issue.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
Current temp is 35.4. Which is good. We turned it to setting 5 and took out the upper drip pan. Lessons learned. Don’t overload and pre cool. Turning it colder doesn’t always help. Thanks to all that replied.
