RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 09-22-2018, 09:34 AM   #1
RichHog's Avatar
1972 23' Safari
Houston , Texas
Water Heater replacement 72 Safari
So I took out the water heater and off to purchase a new Atwood G6 unit with electric ignition. Red and blue water lines go in and out I take it that red is the hot water, blue is pass through cold.
From the original trailer manual it appeases that original didnít have electric ignition, but next to where the heater was on the left side are two green wires laying on the plywood. On the right side is a brown one and a black not connected to anything.
Any insight on this? Thanks Click image for larger version
RichHog is offline   Reply With Quote
Old 09-22-2018, 10:17 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Just guessing but wires could be for the black tank level sensors.
Old 09-22-2018, 11:27 AM   #3
RichHog's Avatar
1972 23' Safari
Houston , Texas
Good to hear from you again Lum.
Good idea, do you know anything about wire colors? Next up will be to replace the cracked black tank. Think somebody forgot to winterize this trailer.
Old 09-22-2018, 11:50 AM   #4
Lumatic's Avatar
1993 34' Excella
Images: 16
Service Manual says black, brown and red.
Old 09-22-2018, 03:51 PM   #5
RichHog's Avatar
1972 23' Safari
Houston , Texas
So wonder what the 2 green ones are next to the w heater? Iíll meter them tomorrow and see if they have 12v in them.
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 08:17 AM
hot water water on demand with a with a normal water heater Frank's Trailer Works Water Heaters, Filters & Pumps 3 09-25-2007 01:24 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 09:06 PM
