07-22-2014, 09:16 PM
1972 23' Safari
santa barbara
Electrical..OK, I surrender!
Trying to fix some electrical gremlins in my 72 Safari23. I have looked at all the schematics that people have posted but nothing matches..close but no cigar. It does NOT have control panel and that seems to be the rub.
So, does anyone know where I can BUY this elusive shop manual that hopefully has the schematic I need..trying to get the water pump going again..pump works,no power to on /off switch by sink. And in all the schematics I've seen, there is no mention of the orange wires that go to this switch., just trying to find where it draws power from..
And yes all the fuses are good!
Thanks!
07-22-2014, 09:27 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
WBCCI #XXXX AIR #2495
07-22-2014, 10:09 PM
Common Sense
Those models used a fuse panel/battery distribution panel that had tendencies to get loose connections where the hardware for the fuse was attached, causing an open circuit. So, just because you have a good fuse in place does not mean you have power going thru the fuse and into the wire. Check with a volt meter to insure you actually have 12 VDC on the wire from each fuse.
Regards,
Steve
07-23-2014, 03:41 AM
1972 23' Safari
santa barbara
Steve ..I already have a new style inverter and a modern fuse panel...it's all good. I'll get the diagram and go from there..thanks for the help guys!
07-23-2014, 07:21 AM
Common Sense
OK, that's good, but you obviously still have a problem with continuity, so I would still test each wire on the fuse outputs for power. Granted the odds are less, but just because the fuse panel is new does not mean it cannot have a problem.
If there is no power at the pump switch, you either have a problem as I describe, or the wire that powers the pump switch is not connected to the fuse panel.
Regards,
Steve
07-23-2014, 11:06 PM
1972 23' Safari
santa barbara
Steve, all outputs from fuse block have power..there are 4 outputs and none of them is orange like the wire going to the pump switch. I can account for all the others. Just not sure where the pump ties in...
FYI, I am a Mercedes Master Tech for the last 35 years so I kinda have an idea what I'm doing. Just need help if someone knows where this ties in. Without a schematic is a bit tricky ...but 100% appreciate the help!
07-24-2014, 01:38 AM
1974 Argosy 26
Morrill
, Nebraska
Have you checked the pump ground/common connection?
Do all other 12 volt devices in the coach work?
Perhaps the orange wire ties into another fixture. ie. 12 volt socket or light fixture.
Send me your email address and I will send a drawing that shows how some pumps are wired. Neither of these drawings show the pump wired directly to the fuse panel.
07-24-2014, 11:12 PM
1972 23' Safari
santa barbara
TG...cool! I ran 12 V direct to pump and it works fine. Ran to power to in side of switch,flip switch, works fine. And everything else is working perfect..
scooterbobby@gmail.com
Thank you!
