RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 12-31-2019, 06:20 PM   #1
1972 23' Safari
PHOENIX , Arizona (AZ)
7 way to 7 way cord
Hi Everyone. Just picked up a 72 Safari and need to know where I can get a 7 pin to 7 blade cord so I can hook up to my 2017 Ram. Hoping to find one pre-wired. I did find a 7 blade cord with wires on other end so I suppose I could rewire the original trailer side AS plug. (trailer side is 7 pin) Idea's?
Jeff.Roberts is offline   Reply With Quote
Old 12-31-2019, 06:47 PM   #2
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Id go simple and cheap and put a std 7 way plug on the trailer cable and make it current wiring matching your TV. Less connections via adaptors is a good thing.
HNY
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Dexter 4 Piston Disc Brakes, Carslile Actuator, Equal-I-Zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 12-31-2019, 08:27 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi Jeff: Welcome to the vintage Airstream hobby and these Airstream Forums. You will find a wealth of knowledge here concerning your 72 Safari.
My 75 Overlander has the same type of double plug cord. I purchased a new cord with the wires open on one end. I removed the socket on the front of the trailer. I ran the new cord down the A frame and under the belly pan to the center front of the trailer. Then I hard wired it to the exterior lighting "circuit breakers" and tested it to make sure everything works.
It takes some work to complete this project, but I think it is worth it.
I never understood the advantage of a seperate cord plugged into the front of the trailer. I like it hard wired to the trailer eliminating potential problems, like a misplaced cord.
David
Name:	1902 7 pin Hole-800x600.JPG
ID:	358449   Click image for larger version
Name:	1902 7 pin Breaker Cover.jpg
Name:	1902 7 pin Wiring Done-800x600.JPG
WBCCI #8607
VAC Region 11
See my 1966 Trade Wind Renovation Documentation:
Knowledge Base Airstream Trailers
See my 1975 Overlander Improvement Journal:
See our 1976 Sovereign Renovation Project:
Old 12-31-2019, 10:41 PM   #4
Trnpk Crsr's Avatar
Baltimore , Maryland
eTrailer sells a cross over cable that has a Bargman end for the tow vehicle and a Pollack end that plugs into the trailer. (if your trailer still has the receptacle)
Cheers,
John
Trnpk Crsr is offline   Reply With Quote
Old 01-01-2020, 10:30 AM   #5
Married with Airstream
drbrick's Avatar
2004 25' International CCD
Vancouver Island , British Columbia
Amazon - picked up what I need to connect my solar panel directly to 'Blue Streak' should find all you need there!
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
drbrick is offline   Reply With Quote
Old 01-01-2020, 07:21 PM   #6
1970 23' Safari
Torrance , California
Hardwired Power Cord
Hi David,
Caught your idea for running a new cable directly to the junction box as opposed to a connector.
Was wondering....
Why did you go under the trailer and up as opposed to through the old hole from the connector?
What did you do with the old hole, an external patch?
As a side note, does anyone ever "catch" the umbilical cord between the hitch and the frame and sever it? I have done it twice (over 30+ years of towing my 1970), both times cut the "brake" circuit and was able to fix it with wire nuts and tape. Now I try to "remember" to snake it through the hitch lock pin. Anyone have any other ideas on how to corral the beast??
Sorry, don't mean to hijack the thread....
Thanks!
Rob
1970 Safari is offline   Reply With Quote
Old 01-02-2020, 07:40 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I ran the new 7 pin cable on the lower inside of the A-frame with clamps and then into the "spare tire" storage area and up through the subfloor. I didn't use the original hole as a guy would need a very good grommet to seal that area from road spray on a rainy day towing. I used a "Colorado state" shaped patch on the exterior skin; very rectangular. I drew a few mountains on the patch.
David
WBCCI #8607
VAC Region 11
Old 01-04-2020, 08:09 PM   #8
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by dbj216 View Post
I never understood the advantage of a separate cord plugged into the front of the trailer.
David
The advantage is that nobody can cut the cord and steel it. How much of an advantage depends where you park.
Question concerning 7-way connector and cord Re-Pete General Repair Forum 5 10-04-2018 12:26 AM
7-way Cord Extension for Hensley Hitch wlanford Hitches, Couplers & Balls 17 06-29-2015 03:45 PM
New 7 way cable (umbilical cord) rbs Electrical - Systems, Generators, Batteries & Solar 7 05-22-2013 12:01 PM
7 Way Trailer Cord aname4me Electrical - Systems, Generators, Batteries & Solar 6 03-09-2011 12:20 PM
