RV News RVBusiness 2021 Top 10 RVs of the Year, plus 56 additional debuts and must-see units → ×
Old 08-31-2017, 03:06 PM   #21
ExStreamin's Avatar
2014 30' International
Ellicott City , Maryland
This might be a dumb question but on a tandem axel trailer is it obvious (from a driving perspective) when one tire is flat? Luckily we haven't had any tire issues yet but it sounds like it is just a matter of time.
ExStreamin is offline   Reply With Quote
Old 08-31-2017, 03:14 PM   #22
2007 22' International CCD
On a dual axle rig, its rather hard to tell, unless you have TPMS or happen to see the chunks of rubber flying off. When he blew a streetside rear tire, son did not immediately realize it had happened.
One of the good/bad things about dual axles is that you don't get immediate handling changes if one tire lets go, so you tend to keep going. That's how the GYM that went totally flat and threw the tread managed to do $4,000 worth of damage to our family AS one time. Fortunately the insurance covered full cost of repairs....
And why we no longer run GYM tires...
Old 08-31-2017, 03:27 PM   #23
ITSNO60's Avatar
Tucson , AZ
Maybe in the not too distant future we will have other options
https://www.wired.com/2015/07/futuri...never-go-flat/
ITSNO60 is online now   Reply With Quote
Old 08-31-2017, 04:44 PM   #24
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Originally Posted by 69bullet View Post
The trailer is a 1969 23' Safari with a single axle. I do use a weight distribution hitch. Speed I dont exceed 60mph, Im towing with my 1970 chevy c10 pickup. The tires are made in China, not saying good or bad about that.
Question, Do 16" rims and tires fit in a 69 single axle wheel well. Where do I find the replacement rims for this.
The 16" wheel and tire combination will only be 1/2" bigger in diameter.
Do you have more than 1/2" clearance between the current tire and the fender/wheel well?
The wheels will have zero offset, but you will have to know the bolt pattern (6 on 5 1/2 or something like that) and center bore diameter.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 08-31-2017, 04:59 PM   #25
ExStreamin's Avatar
So maybe the TPMS is worth the cost? Do you know how much they are to add?
Old 08-31-2017, 05:15 PM   #26
2019 27' Globetrotter
Salem , Oregon
I have been looking at tpms and found the TST brand for $233.00 and the Tire trecker for $289.00. I know there are others but here are two to look at. Dave
NoResults is offline   Reply With Quote
Old 08-31-2017, 05:43 PM   #27
ExStreamin's Avatar
Thanks for the information!
Old 08-31-2017, 07:33 PM   #28
m.hony's Avatar
2013 30' Classic
My Dill TPMS might have been $179 from tirerack.com 2 years ago.
TAC #MS-10
Airforums #70955
Old 08-31-2017, 11:21 PM   #29
LABTOPIA
labtopia's Avatar
1958 22' Caravanner
Atlanta , Georgia
blow out bad rim
just had my first blowout on my 1 axle 58, bad traffic, construction area so no real shoulder in ohio. trailer felt weird then looked in the rearview to see smoke out the wheelwell. found a spot finally to coast to on the side. my AAA would not swap my spare so i felt bad for a few min and got all my tools out. semi's flying by 2 ft away and a state farm road asst stopped and said "dude you are in a really dangerous spot, let me put some cones out and let me know if you need help with anything" George was the most helpful person at the right time.
i put my old a$$ spare on and got to a tire place, turns out the cheap a$$ Chinese rim had a manufacturing flaw and a crack that deflated the tire and wrecked it. it was an ST radial. rim and tire less than 2yrs old. so not always the tire or load, bad rim.
i'm thankfull for helpful people///
Dave Ballard - Full Time Airstreamer WBCCI #4276
https://180sqft.drinkertoys.com/ READ MY AIRSTREAM BLOG
Electric Unicycle Rider (SBU)
labtopia is offline   Reply With Quote
Old 08-31-2017, 11:32 PM   #30
LABTOPIA
labtopia's Avatar
1958 22' Caravanner
Atlanta , Georgia
i replaced my 14.5 with 15, they fit fine in my 58, problem is you have to have a tall jack to change tires to get into the wheel well///
Old 09-02-2017, 01:39 AM   #31
mcomeaux's Avatar
2016 27' Flying Cloud
Sunriver , Oregon
I purchased the TST 507 system. I paid extra for the flow thru sensor and would stick with the standard pressure sensor. The flow thru is hard to get an accurate setting. I really enjoy knowing whats in the tires and the temperature as well. Great system!
Customer service is spot on as well...
mcomeaux is offline   Reply With Quote
Run Flats AS Wantabe Tires 4 01-12-2015 08:03 AM
bonneville salt flats King O D Road Off Topic Forum 3 12-24-2009 06:34 PM
Anybody been to Piney Flats , TN Pappy On The Road... 0 04-24-2007 10:55 PM
What kind of jack do you use for flats, etc? gparker Jacks, Stabilizers, Lifting and Leveling 15 03-28-2007 10:43 AM
Trailer-Aid for changing flats mtpalms Tires 9 06-09-2005 04:37 PM
