02-17-2007, 10:23 AM
#41
1973 23' Safari
Maryville
, Tennessee
Does anyone know what size the Black Water Tank is as pictured above? Also any ideas on where I can get a new dump valve?
02-17-2007, 10:56 AM
#42
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
13 gallons, according to the owner's manual.
don't know about the dump valve, but I do think they're available. you can also get "rebuild kits" for them, too. I got one from my local trailer supply store, but never used it. (the valve seemed to be leaking, but I tried some valve lubricant to fix it, first, and that worked. hasn't been a problem since).
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
02-18-2007, 03:18 PM
#43
1973 31' Sovereign
Portland
, Oregon
Dump Valves...
Check out these folks for dump values and a lot of other things too.
https://www.rvpartsoutlet.com/newstore/nojava/index.cfm
In the index search for "waste valves"
Malcolm
02-21-2007, 02:03 PM
#44
1973 31' Sovereign
Danielsville
, Georgia
Dinette Inspirations
Kevin,
Here's some inspiration for the wrap-around dinette. I've had some time the last week so I've been knocking it out as I can.
I'll fill in the faces with 1/4" oak plywood and eventually trim them out with oak molding. The seats will be framed with 7/8" plywood (not shown) and will be hinged for maximum storage. I will build a table the same way and use matching laminate from the galley.
02-21-2007, 02:10 PM
#45
1973 23' Safari
Maryville
, Tennessee
Looks great Ron. I have mine semi-framed but the floor rot put a hinder on my progress. I have a guy welding new crossmembers on as we speak. Can't wait to get it back later this week to start on the flooring and then on to finishing the dinette.
03-30-2007, 09:00 PM
#46
1973 23' Safari
Maryville
, Tennessee
Making some progress
Got the dinette installed this week, flooring down last week, bathroom in the weekend before. It is finally all coming togther. Still have a lot to do and get my axles, wheels, tires and cushions on Tuesday.
03-30-2007, 10:14 PM
#47
2000 25' Excella
Kingston
, Tennessee
Very Nice! Can't wait to see it when it is done.
03-31-2007, 05:39 AM
#48
1973 31' Sovereign
Danielsville
, Georgia
Kevin,
Looking very nice! Look forward to seeing in Hiawassee. Don't know that mine will be quite as finished as yours by then, but we'll see.
New axles are in the bed of my pick-up as I write and I hope to have them installed this weekend, by Monday at the latest. (I picked them up in Monticello, GA yesterday.)
03-31-2007, 06:34 AM
#49
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Hey, Ron: what are you doing about shocks for the new setup? didn't see any mention of shock mounts on your axle order form....
Kevin: looking good!! post more pics!!
any measurements on the dinette?
Air:291
Wbcci: 3752
'73 Safari 23'
03-31-2007, 10:21 PM
#50
1973 31' Sovereign
Danielsville
, Georgia
Chuck,
You are correct, I did not order shock mounts. This is what I did.
(I purchased 4 new shocks from InlandRV.)
04-01-2007, 08:37 AM
#51
1973 23' Safari
Maryville
, Tennessee
Chuck - I had Dexter include the shock mounts from the factory. I just have to provide the shocks. I will get you my measurments once I drop it off for the install. I will also get the dinette measurements for you.
04-04-2007, 08:44 PM
#52
1971 23' Safari
Portland
, Oregon
kneal,
What was your source for the pedestal of your dinette? I assume it un-attaches easily so that your table top can be taken off and lowered for a front bed?
Thanks much...
04-04-2007, 09:21 PM
#53
1973 31' Sovereign
Danielsville
, Georgia
dmroot,
They can be found at most camping stores as well as online. They also have the flush mount which allow you to throw a rug over them when you're not using the table. The seem to be about as sturdy as the pedestal.
I paid about $6.00 for the pedestals. The post was about $7-$8 (I think).
04-04-2007, 09:33 PM
#54
1974 25' Tradewind
Lake Oswego
, Oregon
Originally Posted by PizzaChop
dmroot,
Hey, I like these! How far did you have to screw into the floor? Thanks, Pam
04-05-2007, 05:52 AM
#55
1973 31' Sovereign
Danielsville
, Georgia
Pam,
I went all the way through and fastened them with T-nuts on the underside (but my belly pan is still down up front).
I would use #12 wood screws about 1-3/4" long otherwise. You do have to be aware that there are steel crossmembers that need to be taken into consideration when positioning a flush mount pedestal.
