Old 09-25-2022, 04:36 PM   #1
breton's Avatar
2014 22' FB Sport
South Shore , Massachusetts
Water heater wont stay on
Hey gang, I have an Atwood g6a-8e (propane only). It starts strong for a few seconds then stops. Any ideas on what might be the problem?
I cleaned all the contacts.
Steve
breton is offline   Reply With Quote
Old 09-25-2022, 05:09 PM   #2
Lafitte's Avatar
2019 25' Flying Cloud
Bullard,Lake Palestine , Texas
Dinosaur
Dinosaur board
I always keep a supply of stimulant handy in case I see a snake ......which I also keep handy
Lafitte is offline   Reply With Quote
Old 09-25-2022, 06:23 PM   #3
1988 32' Excella
Robbinsville , New Jersey
Could be dirt, spiders or something blocking the gas or a bad or poorly adjusted thermocouple.
Old 09-25-2022, 06:39 PM   #4
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
Low or no gas pressure
2023 25' FB with hatch and Queen beds
NCR , Ontario
VE3HIU since 1978
waninae39 is offline   Reply With Quote
Old 09-25-2022, 06:50 PM   #5
DKB_SATX's Avatar
Alamo Heights , Texas
"starts strong" may be open to interpretation, but if you have an audible ignition and the flame is a reasonable color, you may either have a poorly-adjusted or failed flame sensor (so it shuts down thinking the gas didn't light.) As mentioned above, the board and gas pressure are also potential culprits. Usually when the exhaust has spiders or other blockage you get lots of soot and it never sounds "right" if it lights at all, but making sure the tube is clear is good maintenance anyway.
David
Zero Gravitas 2017 Flying Cloud 26U | WBCCI# 15566
Old 09-26-2022, 10:36 AM   #6
wineteam's Avatar
2022 27' Globetrotter
Napa , California
Could this be a flow issue? Water heater senses flow but then quits as the flow sensor stops sending a signal?
We had problems with our shower not getting hot water. I would have to turn on the sink to get the hot water flowing and then the shower. Finally figured out that we almost have to smack the hot water valve into the hot position and then we get sustained hot water flow.
wineteam is offline   Reply With Quote
Old 09-26-2022, 11:01 AM   #7
DKB_SATX's Avatar
The water heater mentioned by the OP is a tank-type, not dependent on water flow for running the burner.
David
leaking shower. Converter box that wont stay in. Closet doors wont shut jclancy General Repair Forum 5 05-29-2019 12:58 PM
new water heater won't stay lit. Aage Water Heaters, Filters & Pumps 16 12-16-2010 05:14 PM
Gas Water Heater Won't Stay Lit somefun LP Gas, Piping, Tanks & Regulators 13 11-02-2010 05:32 PM
Water heater won't stay on Catman6 Water Heaters, Filters & Pumps 12 01-08-2010 11:36 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 05:24 PM
Copyright ©2000 - 2022, Jelsoft Enterprises Ltd.
