08-04-2020, 12:11 PM
#21
2021 16' Bambi
Lawrence
, Kansas
Thanks Jeff! May plan would be to remove the batteries and store them in the TV, and obviously cover the bikes so that they don’t get damaged and filthy from the road trips.
08-04-2020, 12:47 PM
#22
2012 25' FB Eddie Bauer
2009 19' International
Aptos
The best solution is...
Buy an Eddie Bauer or other Airstream with the rear hatch. The Eddie’s come with couches that fold up to give you plenty of room for multiple bikes, plus tie-down brackets to keep the bikes upright while underway.
Ok, back to other solutions...
08-04-2020, 12:59 PM
#23
2004 30' Classic Slideout
Fenton
, Missouri
My RadCity e-bike is 65 lbs with the battery in. My solution is inside storage in my van. While this picture doesn't show the e-bike, it is the method I use and is suitable for both van's and pickup trucks.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
08-05-2020, 12:20 PM
#24
2013 27' FB International
The Villages
Originally Posted by Gulliver72
We carry two folding Lectric XP 20”x4” tired eBikes in the back of the PU. They just fit under the folding hard cover. I’m a former bike shop owner, and these bikes are awesome and VERY affordable.
We do the same with our two RadMinis in the bed of our Tundra.
Scott & Joan
2013 International Signature 27FB
2018 Tundra SR5 DC 4x4 5.7L
Blue Ox Sway Pro
08-05-2020, 05:32 PM
#25
2016 30' Classic
Livingston
Since we fulltime space is a must...so we opted for a.bed cover and slide setup...works well...and still room for storage
08-06-2020, 07:09 AM
#26
Houston
, Missouri
Thanks to everyone for the tips. I'm planning now to make an escape with bikes in the mountains. I hope that it will work
08-07-2020, 08:33 AM
#27
2020 Globetrotter 25 FBT
2020 25' Globetrotter
Wildwood
, Missouri
Just now noticed you were from Houston, MO! I’m sure you are stopping by Piney River Brewery and getting some “Float Trip” brew for your trip. We have a very good friend from Houston.
2020 25GT FBT
2012 Toyota Tundra Dbl Cab, 5.7 4x4
Previous AS trailers: (04) 19’ Bambi, and (11) FC 23FB
08-09-2020, 10:49 AM
#28
2021 16' Bambi
Lawrence
, Kansas
Rucos, you posted, "I made this Aluminum rack and mounted a front hitch on the truck...it has worked great I usually remove the seat...battery and protect the controls if we are traveling any distance. It also has a shakle lock that secures the front wheel to the rack and the bike cross bar is also locked and secured to the rake so it is virtually impossible to remove without a cuttiing wheel. I have about 6-7000mi on it so far...no issues," but there is no picture to go with it; would you please resend it? Thanks!!
01-17-2021, 09:24 PM
#29
2005 25' Classic
Moss Beach
, CA
Originally Posted by Karen-Mike
Since we fulltime space is a must...so we opted for a.bed cover and slide setup...works well...and still room for storage Attachment 375010
HI, after examining all sorts of options for our e-bikes, we feel that the way you have done it is the way to go for us. We do not have quick release front wheels so we are opting for a taller truck cap. Our bikes are 45" tall, plus the height of the slide out -- figure that puts it at about 50 - 55" for the door clearance. We have a 2012 Chevy Silverado HD 4WD, Crew Cab, LTZ, Duramax Diesel with a 6' 6" bed. Any tips suggestions on the type of slide out to get and also the bike rack itself? Also, could you pls tell me what type and model of truck cap you have?
01-18-2021, 06:39 AM
#30
2012 25' FB Flying Cloud
Celina
, Ohio
Originally Posted by waninae39
we have two tern s10 ebikes
with the batteries removed, we use the FIAMMA rack on the rear.
very stable and no issues
Can you still use the rear storage compartment?
01-18-2021, 07:17 PM
#31
1951 18' Clipper
1965 17' Caravel
Ballarat, Victoria
, Australia
This fork mount plate worked well on our first trip with bikes, foam rubber underneath protected the floor, some straps help the bikes in place.
01-18-2021, 07:34 PM
#32
2021 30RB Classic
West Sayville
, New York
This is also a question of ours. The Yakima set up over the bed cover, is this universal or do you need a specific cover?
01-19-2021, 10:00 AM
#33
2017 25' International
Carlsbad
gln826
The cover we use "TruckcoversUSA", has the Yakima base integrated into the cover hardware. I believe that Yakima has a mount system that attaches to the truck they call it the "bedrock".
j
01-19-2021, 10:47 AM
#34
Tampa
Before you invest in the Yakima system and perhaps the Retrax cover, I suggest you watch the LoLoHo video on their E-bikes and this system.
(They quit using it)
01-19-2021, 11:56 AM
#35
2019 27' Globetrotter
McHenry
Mollysdad, thanks for sharing the LoLoHo video. Do you know what they’re using to transport their e-bikes now?
That’s a shame the skewer mount broke the fork on her bike. I suspect the skewer wasn’t tight enough which caused excessive movement and eventually the end of the fork failed.
We’ve had Yakima rail systems for 20+ years, even a tandem bike mount on top of a Chevy Astro van. That was fun to get up there! I took the mounts off the crossbars and made a wood “I” frame out of 2x6 and some pipe to hold the skewer mounts. It fits inside the Airstream with two bikes opposed front to rear. It works but requires some gymnastics to get the bikes on it inside the trailer.
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
01-19-2021, 12:15 PM
#36
2021 30RB Classic
West Sayville
, New York
What about rain/salt/sand/dust? That's my concern as a long trip solution. I think the answer unfortunately is to place them in the trailer. Plus, I can construct an in-the-trailer solution for less than $2,000
Glenn
01-19-2021, 01:41 PM
#37
2020 27' Flying Cloud
Allen
I have a hatch so loading is easier but this could work in a 25 fb or 27 without a hatch. Its a piece of plywood with 2 fork locks and two velcro straps to hold down the rear wheels. I stuff between the bikes and seat bases and between the bikes. nothing moved during transport.sorry photo is a vertical on my computer
2020 FC27Hatch
2022 Chevrolet 2500HD
WBCCI#8934
01-19-2021, 04:43 PM
#38
McHenry
Prostar, I envy you with that rear hatch! It would make it much easier to load bikes into the trailer.
Here’s the wood frame I made and re-tasked Yakima mounts. Sorry for the poor photo but it’s the only one I have. The setup fits in the aisle of the trailer between our twin beds. I put rubber mat on the bottom of the wood; everything stays put.
Our problem now is the DW has a folding recumbent trike. It’s a tight fit getting it through the door. She’s going to try riding a Specialized Como e-bike this spring so that would make transporting easier.
2018 FC23FB
WBCCI# 10258
RETIRED!
01-20-2021, 06:40 AM
#39
2019 25' International
Washington
, Washington, D.C.
I travel solo so only need one bike. I store my 37-pound, folding Evelo e-bike in the truck bed. It fits, with room to spare, beneath my hard tonneau cover. I keep it at the front right corner of the bed on an old quilt. That way, I can slide it out and lift it down. It has worked out very well. And I love the bike. It has a range of 40 miles.
01-22-2021, 09:13 AM
#40
Carlsbad
Just a clarification, Yakima has a bike holder that mounts with the front tire on. No skewer.
I love the LoLoHo team. The mount that they used is different from the "HighRoad" mount. Undoubtedly, all of these systems and mods have their own strengths and weaknesses.
Stay Safe
