10-28-2018, 09:35 AM
#41
Old dog new tricks
2017 19' Flying Cloud
Banner elk
, North Carolina
Same for hanging paper towels
Leave a length of yarn (string, ribbon etc) on holder and simply tie around it when moving. I put my paper towels on a spring rod between kitchen cabinet side and stationery wall and have a piece hangin there for same thing...it was way worse in falling and unrolling as it had much farther to go. Plexiglass cover and all other ideas only if you have time and energy to burn...like the smashing fix also.
10-28-2018, 09:56 AM
#42
2006 22' Safari
Escondido
I cut and slit an empty 2L soda bottle the same width of the toilet paper. We just slip it over the toilet paper when we travel.
Snorky II
Escondido, CA
ESCAPEES SKP 58345
AIR #13642
18 Ram 1500, 06 Safari 22
10-28-2018, 10:32 AM
#43
2014 28' Flying Cloud
Raleigh
, North Carolina
Tp roll
We use an elastic head band. Wraps gentl around I s the paper towel and TP Rolls.
10-28-2018, 10:36 AM
#44
2018 33' Classic
RR #1 Afton
, Nova Scotia
tie a piece or yarn or twine around it
10-28-2018, 10:48 AM
#45
2018 25' International
Las Vegas
, Nevada
Yes it is a silly question 🤨
10-28-2018, 11:38 AM
#46
1973 25' Tradewind
Geneva
You know those little round stickers you can buy in a pack to put prices on things for garage sales? Buy a pack of those and stick one on the loose end of the toilet paper whenever you are traveling. Peel off that piece of paper and toss it when you get to your destination.
10-28-2018, 12:34 PM
#47
Rock Hill
, South Carolina
We use a rubber band on toilet paper and paper towels to keep them from unrolling in transit
10-28-2018, 01:04 PM
#48
'73 Streamline & '51 Spar
Corpus Christi
TP Fix
Easy solution is to tuck a little of the unraveling end in to the roll tube. It has worked for me.
Larry @GoVintageTrailers
10-28-2018, 01:12 PM
#49
Anna Maria
Originally Posted by Lily&Me
Wrap a tiny bungee around it, or use a bit of scotch tape.
Maggie
PS: Don't forget to remove the scotch tape and or the needle before use :-)
10-28-2018, 01:33 PM
#50
International Grey Nomad
1999 35' Cutter Bus Diesel Pusher
Bulahdelah
, NSW Australia
Hi
By far the most simple solution - ignore it. The roll goes nuts very rarely. Spooling it back up is not all that hard ....
Never one for wasting time and energy on jobs that can easily be eliminated. Just a mild squash of the cardboard core will do it. An even better way is to install a holder like this one
https://www.amazon.com/dp/B015GWRN7E..._F6G1BbEQCF8V0
So the roll is pressed slightly against the wall so the friction stops it unrolling
10-28-2018, 03:54 PM
#51
Williamsburg
, Virginia
Toilet paper cover.
I use a plastic small soda bottle, top and bottom removed, with a slit cut down the side from top to bottom. The plastic bottle covers over the toilet paper, and doesn't let the tp roll out. I do the same thing for my paper towels in the kitchen.
10-28-2018, 04:02 PM
#52
2014 25' Flying Cloud
Placerville
Toilet Paper Roll?
Get rid of the Cat..
10-28-2018, 04:07 PM
#53
Murfreesboro
, Tennessee
A rubber band
10-28-2018, 04:08 PM
#54
2007 25' International CCD FB
Northridge
I also use the squish method..even for the extra rolls..takes up less space.
LilNomad
10-28-2018, 04:11 PM
#55
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
Have never had it happen. The tp roller is in a cabinet and it works fine
10-28-2018, 05:17 PM
#56
Bulahdelah
, NSW Australia
Now that that has been solved, should we sort out that other hugely important question being what brand of toilet paper should we use.
Tony LEE
International Grey Nomad.
Travel photos at Picasa Album
Trip map at Spotwalla
10-28-2018, 06:16 PM
#57
2009 27' FB Classic
Sioux Falls
, South Dakota
Simply solution: Stuff end of roll (about 1 sheet) into the tube end. That's what $250,000+ education gets you at Cornell.
Happy streaming
10-28-2018, 06:49 PM
#58
2012 Avenue Coach
Corpus Christi
Finally! An advantage of a wet bath over a dry one.
I can feed my paper the legal way of over the top, and my "water proof" cover door keeps the paper from spooling out while on the road. Win-win!
10-28-2018, 07:16 PM
#59
Dundee
, Michigan
Stuff it in the Kleenex cube, either an empty one or right on top of tissues.
10-28-2018, 08:19 PM
#60
2019 27' Globetrotter
North Bay
, Ontario
Mine hasn't rolled off yet. Although the toilet paper I am using is probably 10 years old. I will be interesting to see if the new paper I bought will roll off. The new rolls seem like little flimsy rolls compared to my old stuff. When I bought it it seemed really cheap and I bought a brand name.
They just don't make toilet paper like they used too.
Or maybe the old stuff had time to really settle and all you need to do is buy toilet paper and let it sit for 10 years - problem solved.
Wow - retirement - who new I would be comparing toilet paper and enjoying it. I take my research very seriously.
On a side note: When I went to build an outhouse for our camp years ago I started looking on the internet for building plans. Well.. there are people who love outhouses and everything you ever wanted to know about them. I guess everyone needs a hobby.
I shall be telling this with a sigh
Somewhere ages and ages hence:
Two roads diverged in a wood, and I -
I took the one less traveled by,
And that has made all the difference.
