Originally Posted by cazual6
I think mine dried out because it does not maintain the water fill. How do I fix?
I replaced the entire assembly this year since mine also cracked and was leaking water on the floor after a while. They can be purchased on the internet (I got mine from eBay - "Thetford 31111 Bravura Mechanism Service Package Toilet", but just noticed it is much cheaper elsewhere). I originally purchased a rebuild kit, but one of the seals was the wrong size even though it was supposed to be for the my model. Then I also discovered that the blade cartridge was also cracked. That is what I ended up ordering and replacing. It made it a lot easier and I would do it again this way. I wouldn't bother just replacing the seals.
It is interesting that some "grease" the blade seal I presume? What type of silicon do you use? I just assumed that my seal failed from the RV antifreeze. There is always some in the bottom of the toilet no matter how hard I try.
