Old 08-03-2020, 05:05 PM   #1
2019 22' Sport
Waynesville , Missouri
Snow Chains Needed?
Hello! Weíre getting ready to go to Yellowstone in mid-September. Iíve heard that some passes get blanketed toward the end of the month. Park Service will insist on snow chains. Iíve got them for my truck. The Ď19 22í FB Sport I have doesnít, yet. Do I even need them? The Sport has standard electric brakes, that may be the driving factor. Any thoughts? Bob, your sage wisdom would be appreciated as well.
DAVSCH is offline   Reply With Quote
Old 08-03-2020, 05:38 PM   #2
2018 25' International
Slidell , Louisiana
If the road has compact snow and ice on it and you insist on driving through it, chains for the trailer are a very wise choice (I'd say a must) because you don't want the trailer passing your vehicle when you apply the brakes. It won't end pretty. You have a bathroom and heat, me? I' wait it out, but a nice pair of cable chains are a would work in a pinch. Don't run them on slush or wet pavement, they might let loose and give your pretty trailer a good lashing.
Brian
Old 08-03-2020, 06:12 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I sure don't tow in snow...especially if they salt the roads...salt + aluminum = corrosion. Not pretty....
If you must "carry them" to appease the Park Service, that's one thing - but I would "sit tight" until they aren't required rather than use them. Also, be quick to wash your trailer (undercarriage too!) if driving through chemical-treated roads, including melted snow.
Shari
RMVAC | ACI - CO Unit (Formerly WBCCI) | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 08-03-2020, 06:46 PM   #4
2019 22' Sport
Thank you BayouBiker. Iíve got Army experience with chains. Most horrible chains you can buy. We just never put them on the trailers. We counted on a 13 ton truck to take the little beasties. LOL. Thanks again!
Old 08-03-2020, 06:51 PM   #5
2019 22' Sport
Shari
Thanks InsideOut! Iím very familiar with salt and chemicals on undercarriages. Around here they spray the roads with chems if their is even the possibility of a snow flake falling. Cars are always white in the winter. Iím the crazy nut whoís washing his car at 38 degrees in the winter trying to get that stuff out of every nook and cranny. Youíre right though, aluminum will be even more reactive. Thanks for the reminder!!!
Old 08-04-2020, 06:21 AM   #6
Slidell , Louisiana
CorrosionX is your friend!
Brian
Old 08-06-2020, 12:21 PM   #7
2019 16' Sport
Nelson , British Columbia
Originally Posted by DAVSCH View Post
Hello! We’re getting ready to go to Yellowstone in mid-September. I’ve heard that some passes get blanketed toward the end of the month. Park Service will insist on snow chains. I’ve got them for my truck. The ‘19 22’ FB Sport I have doesn’t, yet. Do I even need them? The Sport has standard electric brakes, that may be the driving factor. Any thoughts? Bob, your sage wisdom would be appreciated as well.
Hi Davsch, I did several long snowy trips over mountain passes last winter pulling a 16' Sport behind a Ridgeline with snow tires. I wanted snow tires for the AS, but the dealer said "buy snow socks", and in the end I never used them or felt the need for them. OTOH I drive extremely carefully on snow. Top speed for the snow socks (and maybe chains) is 30 mph.
Scott
sdwilsonsct is offline   Reply With Quote
Old 08-06-2020, 01:25 PM   #8
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
I would NEVER put 'CHAINS' on a trailer. Think panel damage from just one loose connection.👎
Cables maybe, if really needed, for a short time👍
Tahawus
"It is more wiser to ponder all things with diligent suspicion, than follow with blind assumption."
RLC
Old 08-06-2020, 02:05 PM   #9
2007 27' Safari FB SE
NW Oregon in a nice spot , Oregon
I suggest you google every state you plan to drive through and look at their chain requirements. Also be sure to check out any discussion about chain requirements for a drag chain on any trailer.
Personally I agree with the "stay put til clear" crowd. I have towed through the mountains in the winter and it is not my cup of tea.
bweybright is offline   Reply With Quote
Snow chains SwampRV Sprinter and B-van Forum 22 10-09-2017 04:30 AM
Towing in the snow? Chains on trailer tires lilynhoward Tires 45 12-15-2015 10:26 AM
Snow chains Mjgman Sprinter and B-van Forum 8 12-04-2015 11:02 PM
Snow Chains interstateflyer Tires 5 06-28-2013 06:55 PM
Trailer chains in snow and ice? jfowler218 Winter Living 14 12-26-2010 07:40 PM
