Huck55, congratulations on your new Airstream and welcome to the community!
I’m sure you’ll get several replies with things to test. You should have gotten a pouch with your trailer that has the Owner’s Manual and a Newbie’s guidebook. Start by familiarizing yourself with both; everything you learn going forward will build on those.
You can break down the delivery process by the obvious visual inspection inside and out. Check all the exterior and interior lights, fridge, range, furnace and heat pump (you may have to wait to test Air Conditioning until it’s warmer but if the heat pump works, the AC should be fine). Check the entry door deadbolt and door locks and the screen door latch. We’ve had to get them adjusted.
Remember, you have a 3 year warranty so don’t sweat missing some stuff. You can test stuff in your driveway too once you are home.
Enjoy your new trailer!
Jeff
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
