Old 07-09-2020, 11:13 AM   #1
2019 25' International
Washington , Washington, D.C.
"No signal" from back-up camera monitor
My back-up camera monitor keeps showing "No Signal" when it's plugged in. I have my truck lights turned on which usually makes it work. I tightened the antenna on the outside as it was a little bit loose. What else should I do to get it working again? Thanks!
PatLee is offline   Reply With Quote
Old 07-09-2020, 11:18 AM   #2
turk123's Avatar
2019 30' Classic
Sunnyvale , California
Do you need to pair it again?
Do you have the 7 pin connector plugged in?
"At some point, throwing money at the problem *is* the right answer", Uncle Bob
x\x/x\x/x\x/x\x/x\101970\x/x\x/x\x/x\x/x\x/x\/x\x/x\x/x
Tom & Doty
2019 Airstream Classic 30 Twin
turk123 is offline   Reply With Quote
Old 07-09-2020, 11:42 AM   #3
mikeinca's Avatar
2020 25' Globetrotter
Santa Rosa , California
You say that you have the truck lights turned on but are the side marker lights on the trailer also lit? (The camera is powered off the same circuit as the lights). If so, then there may be an issue with the connection at the camera or you may have lost the pairing between the camera and monitor. If the trailer side marker lights are not on, then you probably don't have a good connection at the 7-pin connector as turk123 has suggested.
Mike
2020 25' Globetrotter Twin | 2024 GMC Sierra 2500HD Denali Ult. 4x4 Duramax
400Ah Battle Born lithium battery string | 580W solar (400W roof 180W portable)
mikeinca is offline   Reply With Quote
Old 07-09-2020, 12:02 PM   #4
SailorSam205's Avatar
South East , Michigan
What brand of backup cam?
Al
2017 29' SOB, 2024 Platinum F-150 SCrew, ProPride
SailorSam205 is offline   Reply With Quote
Old 07-09-2020, 01:20 PM   #5
Mollysdad's Avatar
Take the monitor in hand and walk back to the camera while the lights are on.
Does it work then?
If not, try pairing again.
Old 07-10-2020, 10:19 AM   #6
2017 16' Sport
Tigard , Oregon
Just move monitor around slowly in your TV to see where you get signal best?
PacificNW09 is offline   Reply With Quote
Old 07-10-2020, 11:52 AM   #7
2018 23' Flying Cloud
Hamilton , Ontario
Just a little reminder. Our backup camera doesn’t work if our lights are on “Auto” they have to be turned to “On”. (We have a Ford F-150)
Ruffit is offline   Reply With Quote
Old 07-10-2020, 01:55 PM   #8
2020 27' Flying Cloud
Howell , MI
What Ruffit said. We also have an F-150. Love the auto headlight setting, but this gets me every time.
BandLAir is offline   Reply With Quote
Old 07-10-2020, 02:41 PM   #9
Glen Carter's Avatar
2018 19' Tommy Bahama
Downey , CA
Same for me and my Cayenne TV, lights must be "ON" to power the backup camera. 2018 TB 19CB...
Glen Carter is offline   Reply With Quote
Old 07-10-2020, 03:08 PM   #10
2020 20' Bambi
Ludlow , Kentucky
backup camera
Same here, My TV is a Jeep Gladiator if light switch is turned to AUTO backup camera will not work...switch turned to ON, camera works.
chappy72 is offline   Reply With Quote
Old 07-10-2020, 03:44 PM   #11
"Cloudsplitter"
We use our 'backup' camera as a rear view camera...it's powered by the AS, when the red light is on the camera is on.👍
POI...we have a signal booster mounted in the propane locker to prevent signal drops.
ID:	372462   Click image for larger version
Old 07-11-2020, 12:30 AM   #12
PC Conner's Avatar
2018 27' Flying Cloud
INDIAN HARBOUR BEACH , Florida
Bob,
I have the Voyager review camera that came with our 2018 27' FC.
Signal drops occasionally. I called Voyager, asked for booster. The customer service rep said they don't sell one. I asked about a longer antenna--bought 15" from another company. Seems to do better but still periodically drops. What booster do you have and where can I find it?
THX
pc
PC Conner is offline   Reply With Quote
Old 07-11-2020, 01:45 AM   #13
2020 30' Classic
DALLAS , Texas
Originally Posted by PC Conner View Post
Bob,
THX
pc
Just go to rvcams.com and get their antenna kit to move the antenna to the front of the trailer. Very easy to do and you will have no more signal loss.
Phantom98 is offline   Reply With Quote
Old 07-11-2020, 08:53 AM   #14
"Cloudsplitter"
Bob,
THX
pc
I've looked for the one we got for our's,(can't find it), it's an older Furrion and would not be compatible with your unit.
Old 07-13-2020, 09:43 AM   #15
Trilla the Traveling Tube
2018 22' Sport
Dayton , Wyoming
Ditto on our 2018 GMC 1500 Sierra!
kpfate is offline   Reply With Quote
Back Up Camera Monitor Question.. Hodgey General Repair Forum 13 07-25-2022 10:56 PM
Side camera "no signal" 2016 AI Njg Sprinter and B-van Forum 3 09-16-2016 02:27 PM
Swift Hitch color night vision back up camera and monitor perri Airstream Classifieds 0 08-29-2016 07:10 PM
Back-up camera and monitor crazeevw Classic Motorhomes 5 09-13-2013 04:59 PM
