Old 11-10-2020, 02:09 PM   #21
KK4YZ's Avatar
2020 28' Flying Cloud
2017 23' Flying Cloud
Hiawassee , Georgia
The crescent shaped (Anderson) levelers and the bubble levels on the outside of the trailer work really well for us.
KK4YZ is offline   Reply With Quote
Old 11-10-2020, 02:35 PM   #22
jeffmc306's Avatar
2019 27' Globetrotter
McHenry , Illinois
+++ for the Level Mate Pro and Anderson levelers. I put the truck in 4WD low and creep forward until the Level Mate app on my phone is green (0.00). Takes all the guess work out of the process. They handle from 1/2” to 4”.
*Stock photo of the Anderson levelers - not an AS
ID:	382957   Click image for larger version
2019 27’ Globetrotter FBT Walnut/Dublin Slate
2018 FC23FB
2019 Ram 2500 6.4 Hemi Laramie Blue Ox 1000#
WBCCI# 10258
RETIRED!
jeffmc306 is offline   Reply With Quote
Old 11-10-2020, 02:40 PM   #23
1960 22' Safari
in the wilderness , The great Mojave Desert
Boondocker here. Where we camp. Nothing is level.
So we park and put the level in the fridge and because we do this so much. We can pretty much tell by where the bubble is and a quick eye job wether we need a 2x4 or a 4x4.
It is not hard.
I'd rather be boon docking in the desert.
WBCCI 3344 FCU
AIR# 13896
CA 4
Yes, we have courtesy parking for you. About an hour North of Los Angeles.
Goin camping is offline   Reply With Quote
Old 11-10-2020, 06:00 PM   #24
2009 30' Classic
a city in west GA , Georgia
Originally Posted by GCinSC2 View Post
No takers on the what's the extra set of lines on the vial for?
Inquiring minds, here ya go. Still has to do with getting stuff to flow.
https://www.thisoldhouse.com/tools/2...nd-use-a-level
Thanks for the info......
Joyman is offline   Reply With Quote
Old 11-10-2020, 06:02 PM   #25
2018 16' Sport
Tacoma , Washington
I make a small ramp using 1 or 2 more lego blocks than I think I'll need and a 2 foot long 2x6 laid on top. Then slowly drive the AS tires up the ramp till wifey yells to stop and the wheels are part way up the ramp.
Obviously being very careful to not drive off the top of the ramp. Also, I try to not go all the way to the top of the lego blocks.
Block the wheels - I use the hard rubber chocks. I think they grip the wood ramp better than the plastic chocks.
No math, no guessing, no trial and error.
I have a single axle. But I have used this method for years on many trailers with dual axles.
2011 Ford Explorer Limited with factory tow package
2011 Harley-Davidson Ultra Limited
Runamuk13 is offline   Reply With Quote
Old 11-10-2020, 06:40 PM   #26
2017 28' International
Jim Falls , Wisconsin
Originally Posted by Atwebs View Post
Gads, you don't need to do the math AT ALL.
Get the half moon type of levelers. Decide where you want the trailer and which side needs to be raised. Slip the leveler(s) under that side and back slowly until it is level. We use a person near our "el cheapo" stick on level on the frame to announce perfection. STOP, chock and you are done.
Way easier than the lego type, no need to think and ultimately adjustable because a little more or a little less is merely a matter of moving the rig slightly.
We spend years with both wood (my husband's father loved that system) and the lego type (that seemed either too much or too little most of the time). But, everytime we use the Anderson levelers we smile -it is just so easy.
Only issue I have heard (and we haven't experienced it) is that they are just a tad too long to move easily when you are "dismounting". Solution is to trim the narrow front part about 1" so they are shorter, but we haven't ever had that issue.
Yep. That’s what i use. Very easy. I just have my wife put the level on the back bumper, and when it is close she tells me to stop. Then lock the brakes, and put the wheel stop in. Unlock brakes. Simple. Cheap. I carry a rubber mallet to knock out the levelers if they get stuck between the wheels. It’s happened once. No big deal.
Daquenzer is offline   Reply With Quote
Old 11-10-2020, 06:49 PM   #27
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I permenately placed a torpedo level on the sill outside of the screen inside the glass on a window over my axles (curbside). I also, installed a large level on the roadside lower edge of our plexiglas rock guard. When I drive up at a site, I maneuver around until large level say I am. Then I use the tongue jack to level the torpedo level. As a last resort, if the fore and aft is not level I pick a spot that keeps our heads above our feet for better sleeping. If the water will stay in the toilet it is level enough for us. I have not used the leveling blocks for years, but I admit the three axles make it much easier and much more stable.
guskmg
Old 11-11-2020, 09:06 AM   #28
1976 31' Excella 500
Chappell Hill , Texas
Fill a glass on the table with beer. If it's uneven, step out and drink the beer while the DW pulls forward and you add a spacer for the tires. Get another beer because the first one was off, and no one likes off beer, then repeat till the glass is even all the way around. Works every time but sometime it takes several attempts.
tbashin is offline   Reply With Quote
Old 11-11-2020, 07:16 PM   #29
West Dundee , Illinois
Those of for plumbers. Poop rolls downhill. They can set the drain pipes at the 1/4" drop per foot they need with those outer lines
RussellG is offline   Reply With Quote
Old 11-11-2020, 07:25 PM   #30
waninae39's Avatar
2022 25' Flying Cloud
NCR , Ontario
we use the Level Mate Pro
Steps
1, pull into the site
2, check Level Mate Pro for L-R
3. place block on the low side
4. pull fwd until level.
5. park , disconnect and move TV fwd
6. level with jack F-B
7. next we lock the 6 Happijac 191025 Jack Stabilizers
now we are level
The Jack Stabilizers are great, they prevent any rocking when parked.
They make HUG difference in the camp ground
waninae39 is offline   Reply With Quote
Old 11-11-2020, 07:37 PM   #31
2009 30' Classic
Ha!really like this idea. We will try this next time
Great!!
Old 11-12-2020, 07:55 AM   #32
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
Originally Posted by pontzdav View Post
The nuns teaching third grade made us learn those times table. I still remember them. Will test the multiply by twelve technique next time out.
There is no math to do, after the calculation is done only one time!
Just remember --- when using a torpedo level, for each ~1/16" out of level, add 3/4" under the low tire.
Alan
Leveling side to side? etojeo On The Road... 101 11-05-2019 05:58 PM
Side to Side Leveling gorrissen Jacks, Stabilizers, Lifting and Leveling 26 08-02-2009 07:50 PM
Power side to side leveling idea truckasaurus Jacks, Stabilizers, Lifting and Leveling 12 10-10-2008 10:43 AM
Side to side leveling: can I use the stabilizer jacks? iAirstream Jacks, Stabilizers, Lifting and Leveling 4 08-17-2007 07:33 PM
