Without the stabilizers down, when you walk to the rear of a 20' trailer [with only one axle and 2 tires] you are at the end of a long lever, and your weight changes the level-status of the entire trailer. Also the tires are not solid objects so they flex when you move around.
If the trailer is entirely level with the jacks down, you are probably
way over-thinking this IMO.
Our owners' manuals say that if the trailer feels level when you walk around it, that is level enough for the fridge.
Our FC20 frames are pretty heavy-duty [apparently] for this short of a trailer, so it is unlikely the frame is bending. Any "rear end sag" you may have read about is for much older and longer Airstreams IMO.
Peter
