Old 11-21-2024, 05:41 PM   #1
RankAm's Avatar
1956 22' Flying Cloud
Dallas , Texas
Is Albuquerque in January not a good idea?
I have a renovated 1956 22' Flying Cloud, and I am contemplating taking her to Albuquerque and Tucson in mid-January 2025. I am concerned about the possibility of overnight freezing temperatures in Albuquerque, where I will be for maybe 4 nights.
My FC has an above-floor black tank, an above-floor fresh water tank under the front window (behind doors that open, which would permit warm air to circulate around the tank, especially if I pointed a fan into that area), and two grey tanks in the belly. All the fresh water plumbing is above or on the floor, and most of it is inside cabinets.
I have a forced-air furnace that easily can keep the cabin warm, but there is no ducting into the belly area. My concern is that the grey tanks (purchased from Vintage Trailer Supply) might freeze.
What is a good strategy to protect the grey tanks? I will be in an RV park with full hookups, so I could drain the grey tanks every afternoon before it gets cold. How about dumping RV antifreeze into the tanks when a freeze is possible? I suppose I could use the FC to sleep, but not use any water that goes into the grey tanks (but this doesn't sound appealing). Is Albuquerque in January just too risky if I want to cook/live in the FC in a way that would add water to the grey tanks?
I would appreciate any advice anyone can offer.
Thanks.
See my 1956 Flying Cloud renovation thread.
RankAm is offline   Reply With Quote
Old 11-21-2024, 07:25 PM   #2
eubank's Avatar
Airstream - Other
Bosque Farms , New Mexico
One possibility would be to add tank heaters. From your discussion, I can see that you're pretty handy because I'd think tank heaters do well with a dedicated 12-volt circuit.
https://www.etrailer.com/RV-Fresh-Wa...77-000164.html
ACI Big Red Number 21043
Old 11-22-2024, 06:08 AM   #3
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
sounds like you will be fine, dumping tanks and only below freezing at night, unhook your city water hose when you dump your tanks and have some water in your fresh water tank to use when off the city water
rbs is offline   Reply With Quote
Old 11-22-2024, 01:58 PM   #4
1994 30' Excella
Mississauga , Ontario
If full hookups why not leave sewer hose connected to grey tanks with drain valves open so the tanks stay empty. Any water you drain from shower or sink would run right out.
Al and Jean
BRN 3845
TAC ON-3
Old 11-22-2024, 02:27 PM   #5
19’ Bambi Flying Cloud
BikeCamper's Avatar
2017 19' Flying Cloud
Airstream Coach - Other
Husqvarnia , Husqvarnia
Thanks.
It’s counter-intuitive, but depending how cold it gets, you might be better off NOT draining the grey tanks before the overnight. For moderately cold temps that only dip below freezing during the overnight, a greater volume of water in the grey tanks is much less likely to freeze than a small amount is.
If you decide to drain the tanks in the evening, I would suggest adding some rv antifreeze to prevent freezing.
2017 Bambi 19 Flying Cloud
BikeCamper is online now   Reply With Quote
Old 11-23-2024, 08:06 AM   #6
RankAm's Avatar
Dallas , Texas
Thanks, everyone, for your advice. I rescheduled the trip to March, so I have reduced somewhat the freezing risk.
Old 11-23-2024, 08:38 AM   #7
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
Alamogordo or Las Cruces is a warmer alternative to ABQ.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 11-23-2024, 10:37 AM   #8
eubank's Avatar
Airstream - Other
A good idea. For what it's worth, it was 23f this morning where I live just outside of (and somewhat lower than) Albuquerque.
Lynn
Thanks, everyone, for your advice. I .the trip to March, so I have reduced somewhat the freezing risk.
Old 11-27-2024, 01:39 PM   #9
2024 27' Globetrotter
Albuquerque , NM
Thanks.
I live here in ABQ... Sounds like you will be ok. The temps here dip to freezing occasionally during the night, but generally not too far. That's not to say that it couldn't happen. I like the suggestion of dumping every afternoon and keeping an eye on the weather.
mejess1964 is offline   Reply With Quote
Good idea or bad idea? stevejones Batteries, Univolts, Converters & Inverters 16 09-19-2018 11:24 AM
Good Sam Roadside Assisstance-Good or not so good? flyingfishy On The Road... 27 05-16-2017 02:37 PM
Is putting cart before the horse a good idea? Is this a good deal on the cart? cantdrv55 Buyer Guidelines 33 11-10-2014 03:17 PM
Original Art in Airstreams? Not a Good Idea! Fly at Night Airstream Lifestyle 12 04-27-2012 12:14 AM
Total electric. Good idea or bad idea? EZstream Generators & Solar Power 34 08-17-2011 09:40 PM
