09-06-2018, 11:13 AM
#21
Don McKelvay
1994 34' Limited
London
, Ontario
Easy - go for a ride in your tow vehicle, open the window and stick your head out. It will blow dry quickly unless it is in the winter.
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
09-06-2018, 11:27 AM
#22
1962 22' Flying Cloud
Raymond
, Ohio
I use the big solar dryer in the sky! after all we are roughing it
09-06-2018, 11:33 AM
#23
2019 27' International
2014 25' International
Boulder City
, Nevada
Sure Jan... what if it is cloudy, raining or snowing? Or if the Sun burns out.
No, I have not been drinking. People with a Sense of Humor, like yourself and others are refreshing. Humor is a terrible thing to waste.
Human Bean
#24
2007 22' International CCD
Corona
Hm. Trying to remember if wife and daughter actually even brought a hair dryer along on last trip. Don't remember hearing it if they did.
Matters not, we usually camp hooked up, and if not, our 3400 watt Inverter generator is nice and quiet when needed.
What little hair I have left dries quickly with a towel.
09-06-2018, 11:45 AM
#25
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
We made every factory 120Vac duplex outlet plus all the others we added run off our Magnum MS-2800 inverter in our 2014 31’ Classic. We have nine 100 watt solar panels charging a 600 amp hour lithium battery. Hair dryer use is a non-issue. We can even run an air conditioner for a lunch break beside the road.
Our 2015 23D International Serenity has the same 120Vac wiring conversion running off a Magnum hybrid MS-3012 inverter. The five 100 watt solar panels feed a 300 amp hour lithium battery. Hair dryer works, but takes twice as long to recharge the battery. We also carry one of our two 2,000 watt Honda generators so with the help of the Magnum drawing startup power from the battery, can even run the air conditioner.
09-06-2018, 12:08 PM
#26
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay
Well I also have a travel butane dryer but have never taken it Airstreaming. I can’t help with OTG blow drying suggestions but I can offer an old modeling technique...when we are OTG I simply air dry my hair for a short time then brush, brush, brush and put in a couple of Velcro rollers while I have brekkie or do makeup. This actually helps hair to dry smoother and silkier than air drying alone. So easy and effective that sometimes I do this even when we have hookups.
☘ 369goose
"The world is a book and those who do not travel read only one page.” – St. Augustine
09-06-2018, 12:33 PM
#27
Kingman
My wife
and I hop in our tow vehicle. I drive and she sticks her wet hair out the window as I go down the highway at 45mph. Seems to work fine.
09-06-2018, 12:38 PM
#28
1966 24' Tradewind
1995 34' Excella
Lynchburg
, Virginia
We boondock exclusively and my wife dries her hair with a low power hairdryer set on low. Our equipment is nothing special- just two golf cart batteries and a 1,000 watt inverter.
Dan
09-06-2018, 12:47 PM
#29
League City
Someone mentioned Conair above.
The FitRV recommended the BaBylissPRO Tourmaline Titanium Travel Dryer. I got one and I love it.
09-06-2018, 01:14 PM
#30
1988 32.5' Airstream 325
WhereIam
, Left Coast Proud
Small low power hair dryer, turn off the AC. So this never happens in the summer. After a while I decided, hey I camped and backpacked for years without it, do I really need it now? No. I wear a perm and let it go curly.
09-06-2018, 01:54 PM
#31
2006 22' Parkway
Poughkeepsie
, New York
Hair dryer
You can buy a 12 volt hair dryer if you really need to have a dryer.
09-06-2018, 02:36 PM
#32
2015 25' International
Scottsdale
Your wife or significant other must look pretty funny bald.
09-06-2018, 02:37 PM
#33
Scottsdale
Oh I need to have a dryer, my hair not to long and not too short. No curl. Vanity you know.
09-06-2018, 02:38 PM
#34
Scottsdale
I didn't realize the number of men that blow dry their hair. Curious.
09-06-2018, 02:40 PM
#35
Scottsdale
Thats an idea, but then you have to tote around a leaf blower.
09-06-2018, 02:46 PM
#36
Scottsdale
Very funny.
09-06-2018, 02:48 PM
#37
Scottsdale
Thank you to all the serious and non serious answers.
Our dry camping is at the Baloon Fiesta. I came up with a solution. Sit in our Ford F250 with the engine running and there is a plug to dry my hair. All is good. I don't want those AS'ers talking behind my back you know.
09-06-2018, 03:07 PM
#38
2015 22' FB Sport
Boothbay Harbor
, Maine
I do the best I can with just a towel or two, and then it's what it is. I won't be seeing any of these people ever again, so as long as I am clean, I'm fine. AND if I DO see them again, and it's not in a camping situation, they will be impressed with my "do". Also, I love hats.
09-06-2018, 03:26 PM
#39
Wolfwhistle
Margaritaville
, Banana Republic
Low heat low or high blower as well as, up to medium heat low blower speed uses less than 300 watts. High and high uses 1800 watts on DW’s. YMMV. Buy a Kill-A-Watt and test. 600w could power medium heat high blower speed.
WW
09-06-2018, 03:57 PM
#40
2018 25' International
2002 30' Classic
1995 30' Excella
Ellensburg
I have a Braun Style Shaper brush and a Braun Curling Iron. We are usually plugged in, but occasionally you find yourself making do somewhere. I towel dry then go outside and brush, brush, brush with the heated butane brush til dry. Then you can go in and use the curling iron. We never had an inverter until our latest AS and haven't had the need to try it.
