02-09-2021, 01:47 PM
demijac
2014 27' FB Classic
Livingston
How Do We Remove Duct Tape Residue From Aluminum Skin?
Does anyone know of a solvent/remover that can facilitate the removal of duct tape residue from the aluminum skin without harming the aluminum?
As background, we broke a side window awhile back and had to live with a temporary cardboard & insulation patch that we duct taped to the side of the trailer. It took us two months before we could get a replacement window installed. When we peeled off the duct tape, quite a bit of sticky duct tape residue remained on the aluminum skin.
We bought something called 'Goof Off' which worked great to remove the residue but left a permanent smudge in the small area we tested so that is no longer an option. Also tried WD-40 but it wasn't effective at removing the residue.
Any ideas anyone? Our main goal is to remove the residue without doing any harm to the aluminum.
Thank you.
02-09-2021, 01:56 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Brakleen has worked removing tape & caulk residue on the roof.
02-09-2021, 02:15 PM
2002 25' Safari
Dewey
Richard
02-09-2021, 02:38 PM
2019 25' Flying Cloud
Airstream - Other
Airstream - Other
North Central Texas
, USA
Keep in mind it's not the Aluminum you are trying to clean, it's the plastic coating on the Aluminum.
WD-40 has worked for me and doesn't seem to cause any problems, perhaps letting it sit for about 24 hours may help.
It may be worth a call to A/S tech support, they have been a great resource for me over the years.
02-09-2021, 02:42 PM
2009 34' Panamerica
2005 28' Classic
Still
, in the thick of it
Many moons ago, I wanted to remove the pin-striping Airstream puts on the trailers. I called the factory and they suggested mineral spirits. Worked like a charm with no ill effects to the coating on the alum.
02-09-2021, 02:44 PM
2015 28' Flying Cloud
2012 25' Flying Cloud
2007 20' Safari SE
Fuquay Varina
, North Carolina
Found this on the internet. I would test in an inconspicuous place first.
Is acetone safe to use on aluminum?
Acetone is fine. Lacquer thinner is a step back from acetone; not quite as aggressive but works well for cleaning most anything gooey. Both evaporate completely, leaving no residue. Neither will penetrate, stain or otherwise damage aluminum.
02-09-2021, 05:58 PM
1969 18' Caravel
Greenville
, whereEverIroam
If the duct tape residue has not yet hardened into a crust, you can easily remove most of it quickly and easily by using a fresh piece of duct tape! It sounds counter intuitive, but it is the easiest and least damaging way.
Take a piece of fresh tape and dab the sticky side onto the residue. If the residue is still a bit tacky, the residue will adhere to the tape more than it will to the surface. This works best when the residue is fresh, just after initial removal of the original tape. This handy tip works for all kinds of tape/bumper stickers/etc. - use the same kind of tape to remove the majority of the residue.
If the residue has already hardened into a whiteish crust, you will need to move onto some oil-based solvents.
02-09-2021, 06:03 PM
2018 25' International
Slidell
, Louisiana
I start with WD-40 or butter, if that does not do the job I try de-solve it but I know for duct tape that won't work very well. Then I go to Goof-Off which you have discovered does the job and sometimes unfortunately does a little more. Other than butter which also does not work very well with duct tape, these ideas have been suggested so I'm out.
02-09-2021, 06:59 PM
2022 Atlas
Homosassa
Turtle Wax makes a label and sticker? remover. I've used it and then I go right back with distilled water and wax or whatever product you use. Wal Mart had the Turtle Wax product here.
02-09-2021, 07:06 PM
Slidell
, Louisiana
You know, now that you mention wax and polishes, I do use polishing compound to remove stains, bugs and tar and crud and adhesive remnants.
02-09-2021, 09:41 PM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Peanut Butter for a non chemical effort. Creamy not chunky.
Hittenstiehl
02-10-2021, 09:13 AM
Newcastle
, Oklahoma
Thank you.
Gasoline on a rag. I've used it many times. It has never damaged the paint or clear coat on the surface I'm using it on. I use a pair of rubber gloves and just dampen the end of the cloth. Then I immediately wash the area with soap and water to remove any gasoline residue. I've used it to remove road tar, paint, and many other types of chemicals over the years.
Better to remain silent and be thought a fool than to speak and to remove all doubt.
02-10-2021, 09:15 AM
2017 25' Flying Cloud
Woodway
Removing Tape Residue
Had this on SOB trailer we had before the AS, where PO had used duct tape or similar to hold up an awning piece whose hardware had come off.
We smeared on some Goop, which will creep downward with a vertical surface, but repeat applications to keep it coated let us wipe all the residue off after a few hours.
I've been a little leery of solvents like acetone, lacquer thinner and such with the plastic coating, but Goop (or GoJo, et al) are pretty benign.
02-10-2021, 09:17 AM
1965 24' Tradewind
almena
, Wisconsin
Cheapest and Abundant!
Gasoline! Pour some of your lawn mower supply on a rag then go for it. Will NOT do anything to the finish...polished, clear coat or otherwise. A little soap and water to finish up after that.
02-10-2021, 09:23 AM
2017 25' International
West Lake Hills
Goo Gone
Goo Gone is more gentle than Goof Off and less likely to harm an underlying finish. New Goof Off is acetone based. It will remove paint and damage some other finishes. Goo Gone is citrus based.
I used Goo Gone to remove from our 2017 International what looked to be very old glue from a sticker. The glue had dried into a hard enamel-like patch. After allowing the Goo Gone to sit for 20 minutes or so, I gently scrubbed the area with a Dobie (non-abrasive) sponge. I took three applications to remove all the glue but there was no damage to the aluminum finish. Then I cleaned it with a mild soap to remove the oily residue.
02-10-2021, 09:30 AM
2007 20' Safari
Old Orchard Beach
, Maine
Hand sanitizer or Goo Gone.
Marty Womer
Old Orchard Beach, Maine
Trailer name: Quarantina
2019-2022 President, Northeast Mountaineers Airstream Club
02-10-2021, 09:35 AM
2017 27' Flying Cloud
Fernandina Beach
, FL
Lacquer thinner.
I used it to remove yellow road stripe paint (don't ask). Worked great and gentle on the skin. I also use it for tar removal.
02-10-2021, 10:07 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
I've always found Bestine to remove sticker & tape adhesives really well. I used it on Duct tape stick-um after having the same 'broken window' situation several years ago. It got the residue off after having been stuck on there a couple of weeks.
Shari
02-10-2021, 10:15 AM
2016 27' Flying Cloud
Overland Park
, Kansas
Kerosene!
02-10-2021, 10:16 AM
Airstream - Other
Airstream - Other
North Central Texas
, USA
Lots of good suggestions here. I wonder if the OP has had any success. It would be great to know what worked/what didn't.
