01-30-2020, 01:26 PM
#21
2013 25' Flying Cloud
Wheaton
I believe the discussion revolves around securing the trailer hitch ball release mechanism.
Greg
01-30-2020, 01:32 PM
#22
2015 27' FB International
Miami
Originally Posted by Mollysdad
I use this.
Called a 'snap lock clevis pin, round'.
An added benefit is I route the 7 way cable through it so the wire never sags on the ground or pulls out in turns.
Yes same here. And it allows a quick release if needed
01-30-2020, 03:37 PM
#23
1986 25' Sovereign
Southern Middle
, Tennessee
This is a Reece pin I bought as a set. It moves the pin further away from the hitch so you can easily grab ahold of it without getting greasy fingers.
PICTURE should be tilted clockwise for correct angle.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
01-30-2020, 05:09 PM
#24
2004 25' Safari
Hanford
"I believe the discussion revolves around securing the trailer hitch ball release mechanism."
In that case I use a Master key lock with a 1 3/4 inch shackle.
01-30-2020, 06:58 PM
#25
1986 25' Sovereign
Huntsville
, Alabama
I use the same as StreaminGeo. I have a set of 3 keyed alike and use 2 for the wheel locks and 1 on the tongue latch. I dont lock it while traveling just incase I need a quick detach. Never lost it yet.
01-30-2020, 07:28 PM
#26
2002 30' Classic S/O
Fleming Island
Attachment 360218
Greg
I believe that is called the coupler.
Al
01-30-2020, 08:10 PM
#27
2018 27' Flying Cloud
INDIAN HARBOUR BEACH
Bolt Locks
I wanted to secure my hitch (easy to steal the trailer by pulling the hitch pen) but hate extra keys. I was willing to pay too much to eliminate a group of keys.
The Bolt system uses my ignition key for all the locks: hitch pen, the lock I installed for the batteries, locks for wheels, the lock for the coupler when off truck (needs modification for Airstream, that is another story), and the coupler latch--all with a key I already have!
https://www.boltlock.com/find-your-lock
I hope you find this helpful.
01-31-2020, 08:16 AM
#28
2019 25' International
Washington
, Washington, D.C.
My initial query should have shown a photo that might have avoided any confusion but my AS is 30 minutes away. However, thanks to your suggestions, I now have what I think I need. Thanks!
01-31-2020, 08:29 AM
#29
Washington
, Washington, D.C.
My initial query should have included a photo to avoid some of the confusion my description caused. SGS - thanks for naming it - trailer coupler pin. I now have what I think I needed. Thanks!
01-31-2020, 08:42 AM
#30
2018 28' International
Mesa
For many years, I have used a long shank Master padlock. I never have to worry about it being removed without my knowledge. Just another option.
02-05-2020, 10:36 AM
#31
Married with Airstream
2004 25' International CCD
Vancouver Island
, British Columbia
Like PC Conner I two use a BOLT lock to secure my Hitch to the TV and I use a Coulper Pad Lock to secure the Hitch Ball Coupler Thingy
La Dolce Vita Brick & Mona
We're Married With Airstream dot com
2004 International 25CCD Registered Name "Blue Streak"
2013 F-150HD FX4 SuperCrew Lariart (MaxTow) "Red Dragon"
02-05-2020, 12:12 PM
#32
Midlothian
, Virginia
I just use a carabiner clip. It's a safety to stop the hitch clamp from opening. I'm not worried about locking it. It does the same thing as a D clip, and I already had it.
02-05-2020, 07:56 PM
#33
2009 25' FB Classic
Scottsdale
Originally Posted by PatLee
Hi all,
I use a hitch pin clip to keep my hitch clip pinned when traveling. Specifically, I'm talking about the clip that goes up and down over the hitch ball area when you're hitching up. (It makes a most satisfying clink or clank when you snap it into place). This link shows you what I currently use.
https://www.amazon.com/Unknown-Hitch...NsaWNrPXRydWU=
Here's my problem. The clips are sometimes difficult for me to push in and pull out and I curse a lot when that happens. I'd like something easier to use. I do NOT want a pin that locks the clip down. I want to continue with something that just pins it in place but easier to slip in and out and gives me the option to do a quick release if necessary. Thank you for your suggestions.
I have a locking hitch pin, plus a pad lock for the AS I don’t trust any one.
Bob & Julie # 5587, 4CU in AZ
02-06-2020, 07:03 AM
#34
2019 28' International
Graceville
I use a good 'ol padlock. I keep the key with my trailer keys. Super easy and also gives some theft protection. You may have to try different sizes to find the right fit. Not a big deal. Happy Camping!
