Old 01-09-2018, 09:36 PM   #1
2018 28' Flying Cloud
Mahomet , Illinois
Front surface protection
Thinking of an Alaska trip. Ive heard thrown gravel and some road debris can be very damaging even with the regular gravel guards. Is there something one can install over your front surfaces to protect against that? Any recommendations? If so, where to obtain or have installed?
wtrclrptr is offline   Reply With Quote
Old 01-09-2018, 11:33 PM   #2
2014 25' FB Flying Cloud
Vancouver , British Columbia
We towed the Dempster to Inuvik last summer. Very little traffic, drove 60-65 kph in 90 zone and still damaged the trailer. The front looked like it had severe acne. Andy Thompson at Cam-Am in London later told me they weld stakes on the tongue and bolt a full sheet of plywood to the stakes creating a 4 by 8 foot cover over the front end. If I had known I would have done that. We had no issues with Top of the World. I have heard the Campbell Hwy is very bad. I highly recommend tire pressure monitors for both the TV and the trailer. We had no tire issues towing 6000 km in the Yukon. The Haines Hwy is very scenic.
RubyDog is offline   Reply With Quote
Old 01-09-2018, 11:41 PM   #3
2016 28' Flying Cloud
Brandenburg , Kentucky
Used this setup from TowTector to tow almost 14k miles round trip to Alaska. Had no dents/dings in AS. I also seriously thought about covering the front lower panels and plexiglass window rock guards with thick yoga mats. I purchased several with the intentions to cover the front but decided to take them with me in case It looked like Id need them. We never exceeded the speed limit and slowed down considerably when the roads got bad. Just watch for the red markers along side the road that let you know that theres an issue with the road and slow down. Enjoy the trip. Click image for larger version
Tsunami-v2 is offline   Reply With Quote
Old 01-15-2018, 09:18 AM   #4
2017 25' Flying Cloud
west plains , Missouri
Roads in alaska
It is all about speed. Gravel guards/mud flaps on Tow Rig are nice and helpful. We did two months in Alaska with nary a ding, but deliberately drove -10 mph on all occasions. The clear stickon plastic sheets used enroute on new cars being delivered will eliminate sand-blasting effect if used on front cowling of trailer. Insulation tubes will protect exposed lines such as LP, and fresh water drain spigots are fairly fragile but easily replaced/repaired. It is a wonderful trip.
rjack is offline   Reply With Quote
Old 01-16-2018, 05:51 PM   #5
Used pipe wrap on all exposed propane lines. Also constructed as sweep, similar to the one on the back of my truck, to protect the gray/black dump valves. Also fabed a couple small pieces of aluminum as a surround to protect the fresh water drain valve. Found that the shroud for the fresh water took a hit and survived it. I rebuilt it and added a couple pieces of large foam pipe wrap, with no other problems
Old 01-16-2018, 08:12 PM   #6
Julie-Bob's Avatar
2009 25' FB Classic
Scottsdale , Arizona
I have a Rock Tamer that bolts on to the trailer hitch part that works great. Cost about $190.00.
Bob & Julie # 5587, 4CU in AZ
Julie-Bob is offline   Reply With Quote
Old 01-17-2018, 11:11 AM   #7
"Hey, I know you!"
Boog's Avatar
Chapin , South Carolina
I've seen these used on Australian outback trailers, looks like a good idea.
trapeze style stone guard
Boog is offline   Reply With Quote
Old 01-17-2018, 01:04 PM   #8
Overkill Specialist
GMFL's Avatar
2020 30 Globetrotter
2014 23' International
Dadeville , Alabama
Best idea Ive seen
Foam yoga mats attached toy the front of the trailer. Replace as needed
Protection for Front of AS tsunami On The Road... 22 06-01-2016 07:39 AM
Front End Protection for Tow Vehicle LOGRIDER Tow Vehicles 15 09-10-2015 06:37 PM
Windows and front body protection Argy 78 Rock Guards, Segment & Window Protectors 6 02-06-2008 01:34 PM
Surface Oxidation Lumatic Ribs, Skins & Rivets 11 01-22-2007 06:28 AM
Brushed Surface Help Randy Johnson Ribs, Skins & Rivets 2 05-05-2003 04:57 PM
