Old 05-11-2021, 10:35 AM   #1
2017 23' Flying Cloud
Hampden , Maine
Fresh water tank
Besides chlorinating and flushing the fresh water tank via the hose connection, is there another way to clean and rinse this tank. I notice there is a plate at the bottom of the tank (~6x8") across from the low point drain that appears to screw off. Having hard water, I wonder if I might hose out the tank more thoroughly from this opening.
airmaine is offline   Reply With Quote
Old 05-11-2021, 12:29 PM   #2
Long Island , New York
Why not take the inspection port cover off, and check this out?
Sounds simple enough to reverse, with the correct sealant IMO. There is minimal water pressure even with a full tank.
What does your owner's manual say?
https://www.airstream.com/wp-content...manual-149.pdf
That inspection port is not illustrated from what I can find. Anything in your actual hard copy?
You might want to check in the Plumbing forum and related sub-forums IMO:
https://www.airforums.com/forums/f163/
https://www.airforums.com/forums/f443/
Good luck,
Let the music lift you up . . .
How to keep fresh water tank fresh and tasting good Driftin Di Fresh Water Systems 26 04-24-2021 05:23 AM
Use Black Water Tank as Aux Fresh Water Tank? DaytonaDan Plumbing - Systems & Fixtures 20 10-26-2016 07:53 AM
waste water tank and fresh water tank size 1964 safari jwmonty72 Waste Systems, Tanks & Totes 1 06-28-2016 04:21 PM
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Using a fresh water tank as a grey tank? Mike&Ali Waste Systems, Tanks & Totes 14 09-16-2010 10:50 AM
