Go Back   Airstream Forums > Airstream Community Forums > On The Road...
Old 07-31-2016, 02:22 PM   #21
abqdor's Avatar
2016 25' Flying Cloud
Albuquerque , New Mexico
Just completed the project yesterday with two gas shocks. One for the medicine cabinet and the other was for the door above the fridge on our '16 25' FB. The installation process was very easy. Directions are a bit weird, I suppose due to translation from Chinese to English and dimensions were in millimeters, but overall it was flawless.
My initial concern was that the medicine cabinet door would be to heavy and need two shocks, but one holds the door up nicely. The door over the fridge is a bit stiff and i would recommend using the next size down from the same company.
Amazon sells them in pairs, so if you want to hold up the medicine cabinet door and settle for the stiffness over the fridge, these are the ones to order.
Apexstone 100N/22.5lb Gas Struts/Gas Springs/Gas Strut Lift Support/Gas Shocks Lift Lid,Set of 4
'17 Ford F-150 Ecoboost, max tow package
'13 GMC Yukon Denali 6.2L V8
'04 GMC Yukon SLT 5.3L V8
abqdor is offline   Reply With Quote
Old 07-31-2016, 09:42 PM   #22
kscherzi's Avatar
2013 27' FB International
El Dorado Hills , California
Images: 24
Nice work!
kscherzi is offline   Reply With Quote
Old 08-17-2019, 04:11 PM   #23
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Measurements
Originally Posted by kscherzi View Post
Nice work!
Any possibility you could provide the measurements for each end of the gas strut? I'm wanting to do this type of upgrade.
tsunami is offline   Reply With Quote
Old 08-18-2019, 08:01 AM   #24
abqdor's Avatar
This comes directly from the mfg. website (which I think is pretty accurate).
Hope this helps.
Pressure:100N/22.5lb (Per Strut);Length ( hole center to hole center) :9-11/16'';Travel:3-14/25'' ,Distance between ball mounts compressed: 6-1/8"
Old 08-20-2019, 01:44 PM   #25
tsunami's Avatar
Images: 20
Should have asked the question differently. Since you've completed the installation, any possibility of getting your specific measurements for each mounting point, example measurements for mirrored door, location of screw holes from top and side of door and inside cabinet, from bottom and front. Thanks
Old 08-20-2019, 02:52 PM   #26
The Aluminum Tent 3
pcskier's Avatar
2014 23' Flying Cloud
Park City , Utah
Hope this helps.
I just got struts delivered and they are 22 lbs as well. The seem really powerful, a lot of pressure just to compress them! I guess the leverage of the door, once installed, helps to close it. My next question is...the spring force, when compressed, seems like it would force the door open! The latches on the mirrored door really keep the strut compressed?
I guess I'm just looking for reassurance!
pcskier is offline   Reply With Quote
Old 08-20-2019, 03:53 PM   #27
abqdor's Avatar
You'll be fine with these struts, particularly on the bathroom mirror door. I only used one and now wished I had used both of them because with only one, the door tends to drop about 3 inches, but then stops. I put the second one on the door over the fridge and it is almost too strong for the small cabinet door. It definitely keeps that one wide open.
Plastic medicine cabinet latches willbrackman Cabinets, Counter Tops & Furnishings 13 02-18-2024 06:00 AM
Medicine Cabinet Replacement 36"x9" outbackbob 1997 - 1999 Safari 2 07-25-2016 01:03 AM
Heavy mirror above medicine cabinet titleists Cabinets, Counter Tops & Furnishings 12 05-24-2013 10:26 AM
'81 Excella Center Bath Medicine Cabinet Latch perryg114 General Interior Topics 10 11-03-2011 12:38 PM
Medicine cabinet door won't stay closed jordandvm Cabinets, Counter Tops & Furnishings 10 10-03-2004 08:24 AM
