Originally Posted by PC Conner
Recently, we were on the way home, about 60 miles to go, on an Interstate/limited access HWY. Duramax engine lost power, I was able to change lanes and get to the shoulder. About when I got to the shoulder the engine died. It would crank but not run. The starter continued to run after I released the key, until I turned to the OFF position.
Things with AAA Premium RV towing worked well but expensive. Covered first $500 of $810 bill. Had it towed to my house.
Truck was towed by USAA to Chevy dealer much closer to my home. No charge. Chevy said the issue is the Fuel Pump Control Unit. That is a warranty item!
Yikes, this got me to thinking about what I would do if this happened last summer crossing the Chesapeake Bay bridge or anywhere along the 2 lane roads on the way to Harpers Ferry, etc.
The engine repair is taking most of a week between waiting in line, diagnosis, approval, and work.
I am not risk-averse and I try to be prepared. This experience makes me very anxious about what I would do with a similar situation far away from home. Towing the truck to a dealership (since it’s a diesel, many repair shops won’t work on it) and then storing the trailer while waiting for the truck repair.
What do you do or what have you done?
Thanks for your thoughts.
It’s good that you made out ok.
Gauges, I try to do as much work on my truck as possible.
2005 Dodge Ram 3500 dually with a 24v Cummins.
I have put full gauges in my truck, LP fuel, injection fuel pressure, oil pressure, trans temp exhaust temp.
There are “engine computers” that will give you most of these.
My mechanic likes me because of my gauges.
My truck is old, she is a keeper!
Mind you, don’t put the computer on your truck because it will void your warranty! After your warranty, I suggest you do several gauges: in importance!:
Pyrometer: exhaust temp, it’s possible to melt pistons in a diesel.
Lift pump fuel pressure: fuel pressure from tank to injection pump
Fuel rail pressure: as we both have a “common rail” system this insures you have sufficient fuel pressure to the injectors. (Plus it’s fun to watch when excelerating.)
Oil pressure, factory gauges are inherently false.
With ANY vehicle, you may never know when something will break, I like and have “full” gauges in all my vehicles, it’s just a piece of mind for me.
Good luck. Rick
