Old 02-26-2019, 01:16 PM   #1
2016 30' International
redondo beach , California
E Bikes X2 Bikes On Top Of Truck Bed
We used 4 Yakima bars to carry the load.
These Yakima racks are rated at 45 pounds each.
Our bikes weigh 50 pounds + with batteries and are real blast to ride around!
ID:	334500   Click image for larger version
ID:	334502   Click image for larger version
Randy and Beth 15 F250, 16 30' International, ProPride, Dexter 3" lift, Michelin 16, Dill TPMS, Centramatics, Battleborn x4, Victron BMV and 1.2KW inverter, Orion DC/DC, BlueSolar MPPT, 300W solar, Alpine iLX, Polk MM1, Samsung smart 42"
mythbuster88 is offline   Reply With Quote
Old 02-26-2019, 01:41 PM   #2
SilverWind's Avatar
2022 20' Basecamp
1968 17' Caravel
Los Osos , California
Wow....that seems like a lot of weight to heft to the top of your bed. Twice the weight of my mountain bikes.
SilverWind is offline   Reply With Quote
Old 02-26-2019, 06:35 PM   #3
2017 30' Flying Cloud
Pleasant City , Ohio
What cover are you using, and how watertight is it?
KCCO is offline   Reply With Quote
Old 02-27-2019, 08:16 AM   #4
Your right! Takes two people.
In real life we take the batteries out. They are 5-10 lbs each.
Old 02-27-2019, 09:51 AM   #5
2018 27' Globetrotter
Orlando , Florida
Exposed Bikes.
Thieves grab these from those set ups in seconds.
Multiple Locks and at least 1 Alarm.
I'd put these expensive bikes in the Airstream if I was driving into town or sightseeing.
Bobfrapples is offline   Reply With Quote
Old 02-27-2019, 10:18 AM   #6
Llittle54's Avatar
2016 23' Flying Cloud
Port Angeles , Washington
Thanks for posting. I just put the same carriers on my Diamondback tonneau cover with the same tracks for 2 Cube e-bikes. Haven’t used it yet. How important do you feel the 4 bars are now that you have used the set up? Did you try with two first? I hadn’t considered 4. The DB cover is solid aluminum that one can stand on. Do you think the cover would influence you choice on the number of bars?
Llittle54 is offline   Reply With Quote
Old 02-27-2019, 06:57 PM   #7
Here is the cover. It is waterproof. But it does freeze shut. Where I live its not a problem.
Old 02-27-2019, 07:11 PM   #8
I used 4 bars because with 2 the bikes would move around a lot especially off road. We also tow a bike trailer that goes up on the bars too.
I have used the 4 bar set up with the batteries in the bikes and it works good. I had to put some rubber spacers between the extra bars and the new Yakima rack because there was a gap.
The cover is independent of the number of bars.
For long journeys we will take the batteries out.
I weighed the bikes today. Batteries are 6 lbs and the bikes 44. total is 50 lbs.
Old 02-27-2019, 07:19 PM   #9
Thanks for posting.
Hey those Cube bike look like a lot of fun!
Old 02-28-2019, 09:54 AM   #10
Llittle54's Avatar
Are the racks attached to the extra bars or do you have them just resting on the spacers.
When you say the bikes moved around off road are you saying that you did try with just 2 bars and it was only the rougher terrain that caused you to decide to beef up?
Thanks for the help. I have my own experimentation to do but it is very helpful to learn from your experience with the exact same set up!
Old 03-01-2019, 10:43 PM   #11
First two bars with normal bikes. They moved around while off road.
Then four bars with heavy bikes. I have not been off road but the four bar setup passed the "speed-bump" test.
The racks rest on the extra bars with the famous split rubber hose spacer technique. Look at the pictures.
Old 03-01-2019, 10:46 PM   #12
The E bikes are more work but way more fun. Go tubeless!
Old 08-01-2019, 05:33 AM   #13
2019 27' International
Western NC , North Carolina
Great idea to double up on the cross bars. Gives me another option as wife’s bike is same as what you have mine is currently a regular mountain bike but I see an ebike coming.
2023 Van Leigh Vilano 320GK
2019 International Serenity 27 FBQ “TC Escape” SOLD
2019 Ford F-350 Platinum
JonDNC is offline   Reply With Quote
Old 08-01-2019, 07:42 AM   #14
Mollysdad's Avatar
Just in case:
Anyone own a Westwood trolley top or other trolley top model? Schneider591 Vintage Kin 2 10-03-2016 05:50 PM
1960's Avion C-10 truck top camper (Rare) ArtisanAir Airstream Classifieds 0 04-12-2016 10:33 AM
Want to carry bikes on front of truck!? 3campers On The Road... 29 11-30-2014 07:25 PM
Top 20 Contributors, Top 10 Forums/Threads & New Stats Info.... Andy R Our Community 7 04-01-2008 09:19 PM
New 25'FB and Truck - Where do Bikes go? P&J Tow Vehicles 40 01-06-2008 05:29 AM
