When I remove the plastic cap on the water pump to access the filter for cleaning - will water spill out of the pump? (Assume the pump is turned off).
Thanks.
Plus . . . in most models the owner's manual recommends . . . when winterizing the plumbing . . . that you disconnect the discharge hose from the pump, and run the pump briefly. A good-sized towel on the floor can catch all this water in one fell swoop! [hot link in blue]
