Old 01-20-2020, 06:21 PM   #1
2020 25' Flying Cloud
Atlanta , Georgia
Carrying Musical Instrument(s) in Trailer
I carry one or two musical instruments with me, and we're in 25, so it's there's not much space. The instruments are a mandolin or mandola and an octave mandolin which is about the size of a classical guitar. I tried stuffing them in the hanging closed (the "large" [!!!] closet), but with the cases in there, there wasn't' room for anything else.
One thought I had Ö the 25 has a cabinet hanging on the forward bulkhed, kind of a "quarter-round" shape. There's probably room to hang an instrument hanger, then I'd have to secure it from banging.
I'm sure others have dealt with this problem. Hints?
Belbein is offline   Reply With Quote
Old 01-20-2020, 06:34 PM   #2
1967 17' Caravel
Pocatello , Idaho
Seems like one of the floor-level storage lockers would be a good place to start, assuming your coach has some? Even if you had to cut a small hole through a supporting bulkhead or something to fit them in, floor-level sounds safer to me. Wrap them in your bedding or stuff some pillows around them to keep them from bashing around.
I sometimes travel with a bassoon, so I understand the problem, but at least it is a fairly simple rectangular shape to deal with!
Good luck!
Vivian
Cerberus is offline   Reply With Quote
Old 01-20-2020, 06:37 PM   #3
Vantair
Vantair's Avatar
2005 25' International CCD
Westlake Village , California
Music Equipment on the road
Hi Belbein,
In very similar 25ft predicament as well. Like you have mandola, full size acoustics/nylon, electrics, pedal steel, Roland drums left behind home based studio setup. No way to bring even one full size guitar and case without loosing severe storage. Worry about the temp extremes which keeps most all at home. Agonizing if and what mics, small mixer/DAW recording interface to pack ! Terrible.
So far, only brought a Baby Tacoma in soft gig bag i wouldn't have to worry about. Perhaps bongos next. Avoiding anything under the touneau truck bed due to extremes.
Relaxing is hard work.
Vantair
2005 25ft International CCD SS
2014 GMC Sierra Denali 1500 4X4 int. 3.43 Int sway/tow controller
1981 Honda Trail CT110 1X0..no sway control
Vantair is offline   Reply With Quote
Old 01-20-2020, 08:43 PM   #4
LEV ZEPPELIN
crazylev's Avatar
2004 19' International CCD
Chicago , Illinois
I just put my instrument on the bed. Iíll then place something with weight like clothes bag against case to keep it in place during travel. Sometimes Iíve forgotten to do this but have not had a problem in 16 years.
crazylev is offline   Reply With Quote
Old 01-20-2020, 10:07 PM   #5
Caffeinated's Avatar
2015 27' Flying Cloud
Portland , Oregon
I keep my acoustic guitar on the queen bed when we are traveling, and in the shower when parked just to keep it out of the way. My uke fits in the closet. I take one or the other, not both.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Caffeinated is offline   Reply With Quote
Old 01-20-2020, 10:46 PM   #6
2018 28' International
Fayetteville , Georgia
A bassoon! Ha! I play a 7/8 stand-up bass...
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 01-21-2020, 08:49 AM   #7
2019 28' International
Bethesda , Maryland
Use Musical Instrument Brackets
We keep the guitar and ukelele on the bed when traveling. When stopped, we have guitar and ukelele brackets mounted to the bedroom wall (curb side that has the thermostat, not the TV).
Here is the guitar bracket:
https://www.sweetwater.com/store/det...r-black-walnut
The brackets are mounted with vhb tape.
Beerboy is offline   Reply With Quote
Old 01-21-2020, 09:58 AM   #8
stevejones's Avatar
2019 27' Globetrotter
Martinsburg , West Virginia
I decided to go with a Traveler Guitar (https://travelerguitar.com/). This is the smallest, lightest guitar there is and has a full size neck/scale. I have both the Ultralight Acoustic and the Ultralight Electric. They are small enough that I keep them in the overhead locker above our queen bed but you could put them just about anywhere. The downsize is you have to amplify it, even the "acoustic". I solve this problem with an audio interface (have both a Line 6 Sonic Port and an iRig HD 2) that plugs into my iPhone and I use apps on the iPhone for amplification/effects. Can run output into Garageband if I want to record. Can listen on earbuds or headphones for private enjoyment, or plug into a small Bose speaker I have to share with others.
Not everyone's cup of tea but I have a blast with it. I played the Ultralight Acoustic in the "Gong Show" at Alumapalooza and used it to play in a worship service at a church in Bend, Oregon -- so these guitars are not toys.
Steve
Steve Jones
2019 Globetrotter 27 FB
2018 Chevy Silverado 2500 4WD LT
stevejones is offline   Reply With Quote
Old 01-21-2020, 10:27 AM   #9
slpiotro's Avatar
2007 23' Safari SE
Madison , Wisconsin
Send a message via ICQ to slpiotro
the only instrument I play is the radio, but my spouse brings her 1950's martin in a guitar (hard) case and leaves it on the bed when we travel. Temps can be somewhat of an issue, but usually we are traveling in above freezing, or to get to above freezing, weather. Re-tuning is required, but it works out quite well. For the person with a full band of instruments, I suspect a follow vehicle is necessary. ;-0
"Honor those who serve by listening to them and caring. Parades end, caring needs to be there every day."
slpiotro is offline   Reply With Quote
Old 01-21-2020, 10:41 AM   #10
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
With our 27FB, we kept our guitar on the queen bed during travel, protected from the windows with bed pillows. It never moved from it's cushioned location. In a 25FB with a sideways bed, I'd do something about the possibility that an instrument could slide forward off the bed in a quick stop, but otherwise, the bed could be a good solution. I'd be worried about using the bed as storage in an RB unit, because you probably get more vertical travel in the back of the trailer, and a quick stop could cause forward slippage.
Rocinante is our 2014 International Signature 27FB
Old 01-21-2020, 12:45 PM   #11
1972 25' Tradewind
1976 31' Excella 500
Denver , Colorado
Like everyone else (from what seems to be trending in this thread), my guitars go on the bed while traveling, and then get shuffled around during stays (usually under the dinette or between the beds).
kidjedi is offline   Reply With Quote
Old 01-21-2020, 01:23 PM   #12
1996 25' Excella
Tillsonburg , Ontario
DITTO ...on the bed and covered with a blanket or comforter to hold them in place. I also lay my TV face down on the mattress and hook the base over the edge of the mattress at the wall to prevent it from shifting....has worked for 20 plus years.
JCW
JCWDCW is offline   Reply With Quote
Old 01-21-2020, 01:25 PM   #13
Chappell Hill , Texas
My electric bass is in a soft case in the closet. Plenty of room in there.
tbashin is offline   Reply With Quote
Old 01-21-2020, 03:40 PM   #14
mikesSE's Avatar
2007 23' Safari SE
ROSWELL , Georgia
Images: 14
Instrument in trailer
Tens of thousands of miles,my Fender acoustic had ridden along in itís Hanger at the foot of my bed,on the cupboard wall.Never has fallen of been damaged.
mikesSE is offline   Reply With Quote
Old 01-21-2020, 07:51 PM   #15
Atlanta , Georgia
Mike: That's kind of what I was thinking about. BUT ... when the trailer is bouncing around on the highway, doesn't the guitar knock into the wall?
Old 01-21-2020, 07:52 PM   #16
Atlanta , Georgia
I guess your wife must tow your trailer. (People usually list their tow vehicle under their trailer description.)
Don't you get any flack about "cute"? I think my wife would punch me. Of course as long as she'd continue pulling the trailer, that's ok.
Old 01-25-2020, 12:57 AM   #17
1967 17' Caravel
Pocatello , Idaho
Well, we're in the same range, but it's hard to find someone to play with since I'm a classical person.
But music is what makes the world go round, wherever you find it! Enjoy your bass!
Old 01-26-2020, 07:58 AM   #18
Portland , Oregon
There is nothing quite like being in your trailer during a thunder storm playing slide in a open tuning.
Mike
2015 27ft FC FB
WBCCI #3960
2019 F150 ecoboost
Old 01-26-2020, 08:05 AM   #19
I was just teasing. My sister plays the bassoon, too.
Old 01-26-2020, 11:14 AM   #20
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
OlyPen , Washington
Images: 90
We travel with instrument cases on the floor and wedged with a cushion to prevent any sliding - no chance of a fall that way. Once parked, cases are moved into the shower (upright) or placed on the upper bunk.
We cut a yoga mat to fill the footprint of the shower. This prevents the case buckles from damaging the tub and can easily be removed/rolled up when needed.
AirForums Custom Search
Janet H is offline   Reply With Quote
Musical LP Regulator cooney LP Gas, Piping, Tanks & Regulators 5 07-12-2008 08:59 PM
Musical Airstream Figaro Member Introductions 2 02-09-2006 03:59 PM
EEEkkkk!! A Trailer Park Musical!!! flamingo-kid1 Off Topic Forum 6 03-08-2005 09:29 PM
Designing a new instrument panel 74Argosy24MH Mechanics Corner - Engines, Transmission & More... 21 09-05-2003 09:00 PM
