Old 02-04-2023, 04:52 AM   #1
Bluetick's Avatar
2018 27' Flying Cloud
bow , New Hampshire
BilleBars
I want to carry two gravel bikes on top of my truck bed. I've been looking at BilleBars since they say they are designed to fit over my tonneau cover. But I'm wondering how I'll be able to roll back the tonneau when needed. Anyone use BilleBars here? What's your opinion?
Praat Afrikaans of hou jou bek.
Bluetick is offline   Reply With Quote
Old 02-04-2023, 07:35 AM   #2
BigSxyWhtGuy's Avatar
2018 30' Classic
Thousand Oaks , California
Not us. We use a bed slide and truck cap to keep our mountain bikes out of the weather and safe from thieves.
BigSxyWhtGuy
Follow our adventures!
@airstreamvagabond on Instagram and YouTube
BigSxyWhtGuy is offline   Reply With Quote
Old 02-05-2023, 05:36 AM   #3
Bluetick's Avatar
bow , New Hampshire
Do you have a stand mounted to the truck bed’s floor? Also do other things ever shift and bump into the bikes?
Old 02-05-2023, 08:08 AM   #4
2020 16' Basecamp
Louisville , Kentucky
I don’t think you will be able to open the tonneau cover wo removing the cross bars. You could purchase a bed rack that may be tall enough to open the cover, but it would be difficult to mount the bikes bc the rack would be so tall. I currently use a Retrax pro xr cover with Sherpa mounts and custom cut aluminum cross bars from 8020.net. I have Sherpa mounts to hold the bars to the track in the cover, and a locking Rocky Mounts for the front thru axle and a rear tire tray with a Voile strap. I apply an ulock on the rear tires when I am away from the truck. It is a great system, but the Tonneau cover does fill up some of the bed behind the cab. Good Luck and happy trails.
Rolind is offline   Reply With Quote
Old 02-05-2023, 09:50 AM   #5
2018 30' Classic
Mountain bikes are axle mounted with a mount from Amazon. I can link if you need the specific one we use. Requires us to take off the front wheel and those are just tied down to the side away from all moving parts with ratcheting tie downs.
Occasionally things run up against the bikes but they are mountain bikes, so naturally have scrapes and bruising. The rub marks don’t bother us and over the years we have figured out how to pack to truck so that things no longer shift around.
In our opinion, the truck cap is the way to go for bike transport if travel is full time or extended time. Otherwise exposed to elements is fine for quick trips or transport.
BigSxyWhtGuy
