11-01-2021, 04:19 PM
2018 27' Flying Cloud
bow
, New Hampshire
Best lightweight floor jack
I keep a lightweight floor jack in my Jeep. It's rated up to 3,000 lbs. Ok for the Jeep but what about my Caravel 22FB? Should I go up to a 2 or 3 ton jack?
Praat Afrikaans of hou jou bek.
11-01-2021, 04:45 PM
1994 25' Excella
Waukesha
, Wisconsin
I recently bought two of these - they are really handy in that they combine the jack function with the safety of a jack stand.
Richard
11018
1994 Excella 25 'Gertie' Follow the build on Gertie!
1999 Suburban LS 2500 w/7.4L V8 'Bert'
1974 GMC 4108a - Custom Coach Land Cruiser 'The Bus' (Sold)
11-02-2021, 10:05 AM
2022 22' Bambi
Villa Park
, Alabama
The best bet for a small lightweight jack that can easily lift your Caravel is a bottle jack. Cheapest place to get one is from a junk yard; usually, they're around $5 or $10.
11-02-2021, 10:12 AM
diesel maniac
Airstream - Other
Tucson
, AZ
Instead of adding all that weight if it's just for tire and bearing service while on the road why not just get one of these? https://www.amazon.com/Trailer-Aid-T...34212847&psc=1
Fast, light, easy and no fluid to leak out.
Plus the 1.5 ton jack you already have would probably have no problem lifting one wheel at a time, but you do have to be very careful how you lift, an improperly placed jack can cause damage to an Airstream so I'm told.
Brian
11-02-2021, 10:30 AM
Alamo Heights
A 22-footer is a single-axle trailer, so that "Trailer-Aid" thing isn't going to do the trick for Bluetick's trailer like it would for a tandem-axle trailer.
Jacking an Airstream is easy if you have a good surface underneath it. Use the flange the axle mounts to as the jacking point, if it can hold the weight of the trailer on the axle, it can hold it on the jack and you don't have to worry about finding a hidden jack point covered by the belly pan, etc.
— David
Tampa
I'd vote for a bottle jack.
I have a nice floor jack from Harbor Freight, 3 ton, the one that Snap-On sued over.
First, it's heavy. It still takes a good grunt to get one side of my 26' off the ground.
Other than crawling under the trailer, a bottle jack has no real downsides.
A floor jack works much better on a concrete floor, not so well on grass or gravel, where you'll most likely be. As the floor jack goes up it needs to move under the workpiece. It won't with tiny wheels and gravel.
11-02-2021, 10:35 AM
Alamo Heights
Oh, and to answer the OP's question directly: I carry a 3-ton bottle-jack. Reliable, doesn't need a regular surface it can roll on, compact. Not really "light" but compared to some big floor jack I suppose it's light. I also carry at least one jackstand because I like suspenders with my belts...
— David
11-02-2021, 10:55 AM
1995 25' Excella
xxxxx
, xxxxxx
Another bottle jack carrier here. I also carry a few boards for a jack base.
11-02-2021, 11:07 AM
2004 28' Classic
Monument
Originally Posted by richard5933
2X Alltrade, but you will need an extension for the handle to lift a heavier trailer. I use a 3 foot piece of steel conduit.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
11-02-2021, 11:09 AM
diesel maniac
Airstream - Other
Tucson
, AZ
didn't know that, thanks...........guess I should stay out of these trailer discussions....
Brian
11-02-2021, 11:31 AM
I'm In
, Kentucky
Honest mistake, there were some 22' with double axle, but not 2022. :-D
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
11-02-2021, 11:47 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
You already have a capable 'jack'.....use it, safely.
I don't trust any jack to "HOLD" anything up, that's what jackstands are for, I recommend at least two for a single axle trailer. I have always used the axle mount plate to lift the AS. And carry lego blocks to allow tire changes,(dual axle AS)
I leave the bottle jacks in the garage. Most do not have an adequately sized base plate....TETO
11-02-2021, 12:04 PM
1994 25' Excella
Waukesha
, Wisconsin
[emoji631]
This is why I used these. They combine a jack with a jack stand. The one one the left is what I'm talking about. The yellow one is there because I'm a belt and suspenders kind of guy.
Richard
11018
11-02-2021, 01:17 PM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
This is why I used these. They combine a jack with a jack stand. The one one the left is what I'm talking about. The yellow one is there because I'm a belt and suspenders kind of guy. Attachment 407385
I like the black one, all 'b' jacks should be so designed.
11-02-2021, 01:51 PM
2018 30' Flying Cloud
Springfield
, Ohio
I've been using the same jacks as Richard5933 for several years. I find that many times I have a place to lift a vehicle but then don't have a place for a jack stand and working under a jack is neither recommended nor safe. Since these are both the jack and the jack stand the problem of not have a place for a separate jack stand is solved. I don't carry these on the road because they're too large. I do carry a smaller two ton, hydraulic jack for that time I might need a jack while traveling. It will get me by in a pinch and placing it on a block of wood solves the issue with the small base.
2018 Flying Cloud 30RB + 2020 Silverado 2500HD Duramax/Allison
