Old 01-29-2017, 04:25 PM   #21
Originally Posted by Isuzusweet View Post
I'm sure we'll see the rims on Ebay soon although you might want to ask for better pics of the fronts.
Cheers
Tony
That. Is. Just. WRONG. Tony....
Another space in the basket for you reserved.
Old 01-29-2017, 04:56 PM   #22
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
Hate to tell you this mate.....I'm the bloody balloon driver!!
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 01-29-2017, 05:08 PM   #23
Richard
2006 30' Classic S/O
Merced , California
I don't know anything about those motor homes but it they have Qudrajet carburetors you should have a mechanic look at them. They are good carburetors when they are maintained but prone to fuel leaks if neglected.
kleimanr is offline   Reply With Quote
Old 01-29-2017, 05:30 PM   #24
Mike1997's Avatar
1998 36' Land Yacht Widebody
Reidsville , Georgia
Images: 14
This fire was awful...from all the posts about fuel lines appears it must have been a motor fire that spread. Glad I have a diesel but now gonna make it a priority to replace the motor compartment insulation with a newer type of sound and fire resistant material.
Mike1997 is offline   Reply With Quote
Old 01-30-2017, 02:42 AM   #25
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
When I had fuel delivery problems after I installed my TBI kit in my 84, I ended up installing an in tank pump and new fuel lines. The old lines were under sized and there were numerous splices with rubber hose on both the supply & return lines.
I used stainless lines and ran them from the rear of the engine under the drive shaft. It may not be kosher, but it got it done.
If you install a aftermarket electric fuel pump you need to make sure that there is a auto shutoff if the engine dies. If the fuel supply ruptures, and the engine dies, you wont be pumping fuel to the fire.
The TBI computer does this if it is wired correctly. Of course if the return line ruptures, it will keep pumping until the tank is empty or power is removed.
WayneG is offline   Reply With Quote
Old 01-30-2017, 05:25 AM   #26
ASTailgate's Avatar
1981 28' Airstream 280
Wow, this happened to mine 1.5 yrs ago. Gas line leak! Hope they got it appraised beforehand as I got raped by METLIFE
ASTailgate is offline   Reply With Quote
Old 01-30-2017, 07:21 AM   #27
1982 31' Airstream 310
Henniker , New Hampshire
Originally Posted by bobmiller1 View Post
Again I say.....more reason for a fire supression system....a solid investment !!!!!
Bob, how do address freezing temperatures with your AFFF suppression system? I assume that agent is water based. I know you have inside storage so that may not be an issue for you; but mine, unfortunately, is stored outdoors. I am wondering if I can install a system or if it will self destruct in the cold.
1982 310 motorhome 502
Henniker New Hampshire
chiefair is offline   Reply With Quote
My Accident, dealing with State Farm Insurance David Ludwig Insurance & Claims 98 08-22-2016 09:59 AM
airstream accident - fire on oregon I-5? janetbjt On The Road... 26 02-10-2007 08:19 AM
accident bhsl8 General Repair Forum 73 09-11-2003 09:27 AM
Trailer accident Ajrandzin Our Community 2 07-01-2003 01:11 PM
